Author Topic: AIR system logic  (Read 3237 times)
Offline 85ckaz
AIR system logic
« on: October 26, 2015, 01:32:10 pm »
I am trying to get a better understanding of how the smog pump system works on my Suburban.  1895, K20, Suburban, 350ci, th400, 4bbl Quadrajet without the mixture solenoid, without an O2 sensor, a HEI distributor without ESC.
I found this helpful information but I want to know more.   http://forum.73-87chevytrucks.com/smforum/index.php?topic=23203.0
I have a temperature sender on top the thermostat housing. I do not know what it does. It does not connect to the water temperature gauge.  The green wire #37 is connected to the gauge.
Where is the air temperature switch?
I passed emissions with great numbers and I do not have catalytic converters in the exhaust system.  (29 ppm HC, 0.14% CO) loaded   (82ppm HC, 0.21% CO) Idle.
Offline 85ckaz
Re: AIR system logic
« Reply #2 on: October 27, 2015, 01:59:34 pm »
thank you
