Author Topic: TH350 Question/Issue  (Read 5014 times)
Offline Militiaman55
  • 74 K10 Cheyenne
« on: October 26, 2015, 07:34:44 pm »
Hey guys!
Hopefully this is something simple. My truck is a 74 K10 with a 350/350/NP205 combo.
The objective is to select reverse from park. When the transmission is in park, I have to first select neutral in order to go back up into reverse. When I go from park to neutral, I don't feel any detents through the lever. However, after I drop into neutral and go back up to reverse, the detents are there, and it's a positive selection into reverse. There is no hesitation into gear and it's nice and smooth.
I've had the truck close to 10 years and it's always done this. It's never been a big deal as I can still quickly and reliably select reverse. I've been working out all the bugs over the years and this one is finally up. A little more info. I just dropped the pan and replaced the filter and 4 quarts of fluid. There was the normal black film, no metal flakes and no chunks in the pan. The trans goes into drive and reverse fine, and shifts well into all gears. Unknown mileage.
I'm hoping this is an adjustment or other simple issue. I've followed the linkage adjustment procedures in Haynes/Chilton manual with no improvement. Any ideas?
Thanks!
Rob.
Offline aaronboss221
Re: TH350 Question/Issue
« Reply #1 on: October 26, 2015, 08:10:50 pm »
Mine was like that with drive. I had to go slightly passed it then back. It was a little rubber grommet under the hood next to steering column. Sorry I can't more thorough with names I am quite new.
Sent from my VS986 using Tapatalk
  • 74 K10 Cheyenne
« Reply #2 on: October 28, 2015, 10:59:04 pm »
I will thoroughly check my linkage. Thanks for your reply!
Rob.
« Reply #3 on: November 05, 2015, 11:11:04 pm »
« Reply #4 on: November 05, 2015, 11:13:39 pm »
could also be you just need to adjust the shifting linkage if your bushing/sleeve is in "ok" condition
Offline Dan75k20
« Reply #5 on: November 11, 2015, 10:08:18 am »
The teeth on the gear slector inside the trans could be worn out.
  • 74 K10 Cheyenne
« Reply #6 on: January 14, 2016, 11:29:25 pm »
Thanks a lot guys.  I think it's actually the whole collar the lever goes into on the steering column. Pretty worn out there, but everything else I can see looks okay.
