Author Topic: 2-2.5 inch lifts  (Read 9296 times)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
2-2.5 inch lifts
« on: November 06, 2015, 06:52:07 pm »
I am looking at possibly doing a 2-2.5" suspension lift on my '85 K10 6.5 diesel-I don't like body lifts-I will probably just get new springs for the front, as mine seem rather worn, especially the passengers side for whatever reason, the frame sits 1/2-3/4" closer to the ground on that side.
So what I currently have is 4/1 rear springs, should I try and get them rebuilt, 5/1, and get a 2" re-arch done to them, or just do an add-a-leaf?, and can I reuse the shocks? I have to double check the extension, but I think it was 23" front 21" rear??
I don't want any more lift, as I don't want to get larger tires(I feel 33's are minimum for 4". and I have 4 brand new 31's on it), oh and no blocks, I don't like blocks either
oh, and brands to look at for springs, and AAL's-if I end up going that route. Ride quality don't matter much, I drive 1-tons for work-and those have like no suspension movement
Thanks all
 1986 Chevy K30(under repair)
Offline 85ckaz
Re: 2-2.5 inch lifts
« Reply #1 on: November 25, 2015, 11:59:10 pm »
I have had leaf springs re-arched and they did not last.
 I ended up going to a spring and U bolt shop and they made me 2" lift, 3/8" thick leaf, 10 leaves, rear springs. I then went to a 4x4 shop and bought a Rancho lift kit with new front lift springs, Procomp ES7000 shocks and all the small parts. It was around $200 cheaper to buy the lift kit than buying all the parts one at a time.
« Reply #2 on: November 26, 2015, 09:17:10 pm »
thats something i never understood. if metal is fatigued and bent and you straighten it out it is weaker than it was originally and will bend easier than before. now granted this is the opposite of springs but metal is metal and its still weakens over time
Offline lyndoncp
« Reply #3 on: November 26, 2015, 10:06:12 pm »
I am actually wanting to do the exact same set up on my k10- (2 inch suspension lift with 31's.)
Would you please post a picture when you are done??
Offline Greybeard
« Reply #4 on: December 23, 2015, 11:57:10 am »
This was discussed in another thread. A spring can be reached but to do it right is more expensive than buying a new spring. The spring would have to be annealed first, then bent, then re-hardened, and tempered. So most shops will simply cold bend them over the original specs which stretches the molecular alignment of the steel, weakening it. It's all at the molecular level. Just like soft copper can only be bent X number of times before it's not soft anymore and breaks instead of bending.
