Author Topic: upgrades for better burnouts?  (Read 14019 times)
Offline TJ Kollmeyer
« on: November 14, 2015, 10:58:18 pm »
Hi, i have a 1983 Chevy k10 with a 5.7L 350 swap on the turbo 300 3 speed automatic trans. it has 6 inches of suspension lift and 33" superswampers.
I have recently done some upgrades since i got the truck, such as adding an edlebrock performer intake and a holley 600 carb, but the truck also has
 -accel supercoil ignition coil
 -mild comp cam
 -dual exhaust w/ long tube headers
 -few other random things
 -aftermarket air cleaner
 -valve covers / breathers
The main thing im wondering is what i can do now to make my truck do burnouts, because it barely has enough tires to brake torque as it is, sometimes it will, most times itll just scream really loud but not spin the tires. What upgrades can i do now to make the truck spin the tire(s) consistently?
Offline Jr.
Re: upgrades for better burnouts?
« Reply #1 on: November 15, 2015, 02:36:46 am »
What camshaft are you using? (Lift, duration, lobe separation)?
Sent from my SM-T217S using Tapatalk
« Last Edit: November 16, 2015, 09:46:36 am by Jr. »
Offline fitz
« Reply #2 on: November 15, 2015, 03:59:35 pm »
Get a line lock.
Offline enaberif
« Reply #3 on: November 15, 2015, 04:30:07 pm »
Doing burnouts in a heavy 4x4 truck is not a good idea as you will end up breaking something.
But if you insist .. a line lock will be your best bet.
« Reply #4 on: November 15, 2015, 05:32:53 pm »
a little oil will help, better yet put it in low with front hubs unlocked
Offline chevybones87
« Reply #5 on: November 15, 2015, 08:54:13 pm »
When I was younger I had an 85 model with 35's on it, also a built 400 small block and 3 speed trans.. Smoked the tires first time...second sheared all my universal joints clean.....< lesson learned lol
Offline Joec123able
« Reply #6 on: November 15, 2015, 10:32:10 pm »
Why would you want to do burnouts in a lifted truck with bigger mud tires on it? Makes no sense to me, seems like if you wanted to do burnouts you'd build a street truck not a mud truck.
Offline fitz
« Reply #7 on: November 16, 2015, 09:18:29 am »
We were all young once.
Before I bought my 81 step side off a friend of mine, I have great memories of him doing donuts in it with the smoke pouring off the 44" Super Swampers.
Ujoints can be replaced, memories last forever.
« Reply #8 on: November 16, 2015, 09:42:43 am »
yes i remember loving to smoke my tires. now i just think of what bill smoking a tire will cost me from paying lol. getting older sucks
Offline Gwtt
« Reply #9 on: November 19, 2015, 09:51:27 pm »
Gearing is your answer. with the larger tires your engine has to work harder, by gearing it you will get your acceleration back, and the torque can be applied better to break loose those bologna's!
Offline MEXICANKAMIKAZE
  • Chevy Padawan
« Reply #10 on: November 19, 2015, 11:45:04 pm »
not an expert on anything with a motor in it but some advice that was shared with me years ago was get a stick and ditch the automatic
« Last Edit: November 20, 2015, 06:56:28 am by Irish_Alley »
Offline Captain Swampy
  • Wisconsin
« Reply #11 on: November 21, 2015, 08:09:01 pm »
Lower gears and put a vice grip on the flexible rear brake line. Put something smooth under the jaws.
Offline frotosride
    • WFO CONCEPTS
« Reply #12 on: November 21, 2015, 08:23:46 pm »
AKA.... Redneck line lock.
 But gears,gears gears! I have no problem smoking my 35's and I only have 3.73's in the rear. Granted the extremely low first gear of the 700r-4 helps a lot to. I'm not that young anymore so bills and 4 kids keep me from doing this to often however the third day I was down here in GA I took the kids on their first ever mud ride but no water over 3ft bc I'm not so sure we are allowed to be where we were.
« Reply #13 on: November 22, 2015, 06:53:57 am »
for some reason my 91 crew with only 28s wouldnt do a burn out with the 350 and still wont with the cummins. i imaging it due tot he rear brakes being improperly adjusted
Offline frotosride
    • WFO CONCEPTS
« Reply #14 on: November 22, 2015, 08:04:17 am »
Aaah are the really necessary!
