Author Topic: This dont line up! All OEM..  (Read 11895 times)
Offline philo_beddoe
  • 77 C-10
« on: November 20, 2015, 10:08:03 am »
Any suggestions on how to connect? Cut in half and use a flex tube!  All i can think of, this engine came with a two barrel and now its a four bbl.
Offline LTZ C20
Re: This dont line up! All OEM..
« Reply #1 on: November 20, 2015, 02:08:14 pm »
The tube is installed upside-down...
LTZ Cheyenne C20
  • 77 C-10
« Reply #2 on: November 20, 2015, 03:35:35 pm »
No sir, i tried the other way.  Both ends will fit the way i have it.  But the air clnr is too far over.  I think if i cut it in half and put a metal flex in the middle it'l go.  And i cant move the air clnr to the left, then everything else will not align.
Offline enaberif
« Reply #3 on: November 20, 2015, 10:21:18 pm »
This is why most of those tubes are flexible metal for. Different air cleaners, carbs, intakes etc can make things sit in completely different places.
« Reply #4 on: November 21, 2015, 05:48:26 am »
Wrong air cleaner for that tube.  Your heater hoses are too short and should lay on the fender well btw
  • 77 C-10
« Reply #5 on: November 21, 2015, 08:05:41 am »
Ya know zieg you right!!  Never really noticed, thanks. Gonna fix those hoses today, get a flex tube and make this thing work.  And good point enaberif.
  • 77 C-10
« Reply #6 on: November 21, 2015, 08:13:51 am »
I thought it was the wrong air clnr too, but the snorkel lines up perfect to the unit on the grill, that big 4 inch adapter piece.  Oh well,
Offline LTZ C20
« Reply #7 on: November 21, 2015, 12:15:42 pm »
I know, I was kidding.
LTZ Cheyenne C20
  • 77 C-10
« Reply #8 on: November 21, 2015, 02:26:38 pm »
Oh, gotcha...
  • 77 C-10
« Reply #9 on: November 21, 2015, 05:57:46 pm »
Ok, hows this (zieg)?
« Reply #10 on: November 21, 2015, 06:02:34 pm »
Awesome, I approve and your warm ups will be more pleasant for sure
  • 77 C-10
« Reply #11 on: November 21, 2015, 06:34:52 pm »
Thanks! I know your tough, your approval means a lot!! I had to cut the black tube in half (painted with high heat) at both end the black tube goes deep into the flex. I already tried starting cold, warms up fast!! Kicks down to normal idle in about a minute. Love it. Next! Wait, next was the heater hoses, done! Next!!
Offline Jr.
« Reply #12 on: November 22, 2015, 11:17:15 am »
Determination!!!!!
Sent from my SM-N910P using Tapatalk
  • 77 C-10
« Reply #13 on: November 22, 2015, 07:00:37 pm »
You know it, was bored for a few minutes today so i painted the flex tube, added a hose clamp, put a little RTV under the edge of the valve cover because of a stupid tiny oil drip leak thats been buggin me, and coated the underside of the truck. These trucks are a full time hobby, never ends!!!
Offline enaberif
« Reply #14 on: November 22, 2015, 08:18:28 pm »
Fix the valve cover correctly and it won't leak :P Its lack of prep work that makes those things leak and lack of proper equipment.
