Author Topic: 1973 C10, what is this part near the coil  (Read 6772 times)
Offline jontsa
« on: November 25, 2015, 03:10:19 am »
A stupid question but here goes :)
1973 C10 with a 454. The engine should be original though I haven't verified this yet. On the coil mounting bracket there is a small one wire thingy-ma-bob that is not connected to anything. What is it for and where should it be connected to? :)
Offline hatzie
Re: 1973 C10, what is this part near the coil
« Reply #1 on: November 25, 2015, 07:34:16 am »
Radio noise suppression condenser (capacitor).
Offline jontsa
« Reply #2 on: November 25, 2015, 08:02:46 am »
And this connects to the positive terminal in the coil?
Offline timthescarrd
« Reply #3 on: November 25, 2015, 09:02:04 am »
it would connect to the Tachometer signal wire if you have a tach, it's designed to reduce "noise" and thus keep the tachometer more smooth
Offline jontsa
« Reply #4 on: November 25, 2015, 10:04:00 am »
The car has the original tach, though it's not working. The distributor doesn't have separate tach signal and the tach is connected to the negative terminal in the coil.
Offline Captain Swampy
  • Wisconsin
« Reply #5 on: November 25, 2015, 04:47:20 pm »
It keeps the points from arcing or burning. It has nothing to do with the tach or radio interference
1987  350TBI 700R4  4X4  4.56 gears  33" BFG All Terrain
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32209.0
Online bd
« Reply #6 on: November 25, 2015, 06:08:41 pm »
On the contrary, the capacitor (condenser) that buffers arcing across the points is located inside the distributor near the points.  The externally mounted capacitor in the image is intended as a noise suppression filter as previously stated.
« Reply #7 on: November 25, 2015, 06:53:07 pm »
Yup and they were also installed on fan blower assemblies too
Offline hatzie
« Reply #8 on: November 25, 2015, 06:54:41 pm »
Beat me to it.  The noise suppression cap is on the positive terminal of the coil.
It's for the tach and the radio.
From orbit on my Android.
Offline jontsa
« Reply #9 on: November 26, 2015, 01:24:21 am »
This cleared it up. Thanks for all the answers :)
