Author Topic: Transmission leaking into transfercase  (Read 3815 times)
Offline josh0325
« on: November 29, 2015, 11:52:34 am »
Did transmission/transfer case swap on 1990 suburban. Transmission was a 2wd th40O from an R.V. I removed the tail housing,cans mounted a short input NP205 case to it.  Before installing I replaced the o-ring and seal in the axapter, and the gaskets.  My trans is leaking fluid into the transfer case, did I overlook something???
Offline Engineer
Re: Transmission leaking into transfercase
« Reply #1 on: November 29, 2015, 08:19:26 pm »
The seal lip with the garter spring should be facing the transmission.
There are seals available that have a double sealing lip. Those are the preferred ones.
Other than that the only thing I could think of is maybe, possibly, you somehow cut the sealing lip when you were installing the transfer case.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline josh0325
« Reply #2 on: November 30, 2015, 07:28:34 pm »
That's what I was thinking too is if I cut the lip of the seal. Man, that case is awkward for one guy.  Where can I find the double lipped seal at if that's the case?
Offline blazer74
« Reply #3 on: November 30, 2015, 09:27:38 pm »
Hard to find the double lip seal, parts stores will have a note if they read it that says use two of this #.
Back to back, one facing to the TC and the other facing the adapter.
Found this out years ago, maybe you can get the double lip seal nowadays
Offline josh0325
« Reply #4 on: December 01, 2015, 09:01:31 pm »
That makes sense, thanks for the advice.
