Author Topic: 1981 2wd auto to 4wd manual cab swap  (Read 4793 times)
Offline jhiggin
« on: December 23, 2015, 09:45:55 am »
 This truck is in the middle of restoration so I would like to be sure before I paint under the cab that I have the trans tunnel correct. Do y'all think that the way I have it now will clear the transfercase or do I need to find a bolt in transfercase hump. Keep in mind this was an auto cab I just added the taller tranny bolt I'm hump.
Re: 1981 2wd auto to 4wd manual cab swap
« Reply #1 on: December 23, 2015, 06:36:00 pm »
If you swapped to the tall hump it should clear.
Offline mikek20
« Reply #2 on: January 16, 2016, 01:02:56 pm »
My truck cab is 2wd auto with small hump. It clears my transfer case, no body lift. I did however lower the cross member by taking the spacers on inside of the frame rail and moving them to under the frame rail to lower the cross member. It all fits perfect
Offline 5l1p5tr3am
« Reply #3 on: January 27, 2016, 03:59:27 pm »
Same way mine was done... though I didn't realize it until I bought a carpet kit with a high hump and it did't fit.  :o
1979 Chevy Frankenstein
C10 diesel converted to 4x4 with 307/350/203
« Reply #4 on: January 30, 2016, 08:43:00 pm »
By lowering the transfer case cross member you are making the front drive shaft angle worse.
