Author Topic: 396 fitment  (Read 3128 times)
Offline Wesleyak47
396 fitment
« on: January 09, 2016, 09:47:59 am »
1984 chevy c10.
Hey guys my motor currently went out so I'm looking into a 396 will it fit right in and bolt to a 700r tranny?
Sent from my SM-N910V using Tapatalk
Re: 396 fitment
« Reply #1 on: January 09, 2016, 10:27:18 am »
Yes the bell housing bolts are the same on all Chevy engines, v-6 4.3L all the way through the big block.  Some have said the engine clam shells are specific to big block and of course you would have to have all the components from the big block if you are replacing something smaller.  The flex plate for the 396 will not have the bolt hole pattern for the torque converter if it is original.  Not sure if the replacements have both patterns on them.
Offline Swettracingc10
Re: 396 fitment
« Reply #2 on: January 26, 2016, 11:16:41 pm »
Sure will! Like zieg85 said the flex plate will be the only issue. Either drill the proper holes in the one that comes on the big block or order a flex plate to match engine/tranny combo. They are relatively cheap.
Sent from my LGLS990 using Tapatalk
