Author Topic: HELP PLEASE.  (Read 10754 times)
Offline 86BigblockGMC
HELP PLEASE.
« on: January 30, 2016, 12:29:26 pm »
I recently lowered my 86 Silverado SWB. i used 3' DJM drop spindles and 2" lowering coils. along with Nitro Drop Shocks 2. Also did a flip kit for the rear. my question is after i installed the rear flip kit my rear end is cocked... the driver side rear tire is closer to the outside of the fender than the passenger side. I do not see what i did wrong or how this even happened? This is my 4th 73-87 c10 ive done and this is the first time this has happened. any help would be greatly appreciated. i also had to get my driveshaft shortened because it changed the geometry that much. again, that was a first time i had to do that also.
Any suggestions????
thanks.
Offline FlatBlack77
Re: HELP PLEASE.
« Reply #1 on: January 30, 2016, 02:21:38 pm »
how much closer is it?
my first thought is the bed is messed up. maybe body work from years ago. same thing happened to my beater civic. when i dropped it down one tire was touching the rear fender lip and the other wasnt. so i looked closer and come to find out that entire quarter panel was replaced
Re: HELP PLEASE.
« Reply #2 on: January 30, 2016, 03:13:19 pm »
did you put the springs in the same direction?
Re: HELP PLEASE.
« Reply #3 on: January 31, 2016, 07:13:13 am »
Everything was even and pretty much spot on before lowered it. I'm not talking about the tire being to close to the top of the fender... I'm saying if you were to grab both tires at once and had the strength to move the rear end then the driver side rear is pushed forward. And when I look at the leafs the driver side are tweeted. Ride height itself is almost perfect. Driver side is a 1/4" higher than the passenger side.  But when you are standing behind the truck and you look at the rear tires, you can clearly see the driver side is more forward than the passenger side.
Re: HELP PLEASE.
« Reply #4 on: January 31, 2016, 07:14:48 am »
I sure did. I know it's something simple. And obviously something I did. But I don't see how it happened.
Offline frotosride
    • WFO CONCEPTS
Re: HELP PLEASE.
« Reply #5 on: January 31, 2016, 08:50:17 am »
Pics...
Offline FlatBlack77
Re: HELP PLEASE.
« Reply #6 on: January 31, 2016, 08:53:03 am »
maybe one of the leaf pack studs didnt make it into the hole on the flip kit bracket.
correct me if im wrong but the flip kit brackets have the hole dead center right? they cant be backwards?
Re: HELP PLEASE.
« Reply #7 on: January 31, 2016, 09:21:09 am »
The holes are offset. I was guessing that too. I'm about to head to the garage and take pics. I will post them in a bit.
Re: HELP PLEASE.
« Reply #8 on: January 31, 2016, 10:39:21 am »
Re: HELP PLEASE.
« Reply #9 on: January 31, 2016, 10:40:03 am »
Re: HELP PLEASE.
« Reply #10 on: January 31, 2016, 10:40:29 am »
See how far forward the driver side wheel is?
Re: HELP PLEASE.
« Reply #11 on: January 31, 2016, 10:41:07 am »
This is the passenger side.
Re: HELP PLEASE.
« Reply #12 on: January 31, 2016, 04:44:45 pm »
that left spring looks like its kicked out a lot
Re: HELP PLEASE.
« Reply #13 on: January 31, 2016, 05:27:37 pm »
It is. Think I may have figured it out.
