Author Topic: Poor Ride Quality  (Read 18391 times)
Offline 86BigblockGMC
Re: Poor Ride Quality
« Reply #15 on: February 23, 2016, 08:49:41 pm »
Finishing up the motor before I take it and get the alignment. I don't drive it. Sits in my garage. Just gathering parts to finish the interior etc.
Offline roundhouse
« Reply #16 on: February 24, 2016, 05:53:57 am »
Try driving it without the shocks
« Reply #17 on: February 26, 2016, 11:06:25 pm »
Yeah I will pass on that. Looking for solution to this problem.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #18 on: February 27, 2016, 06:48:39 am »
I think he was trying to eliminate the shocks(although new) as bad or limiting travel
 1986 Chevy K30(under repair)
Offline roundhouse
« Reply #19 on: February 27, 2016, 10:45:08 am »
well yeah
How else are you going to know if the stiff ride is caused by the shocks or by the springs ?
You have to unhook the shock mount on one end and zip tie it safely out of the way
And then take it for a drive around the neighborhood
If it rides a lot better then the shocks are too stiff and are your problem
If it still rides stiff. Then your problem is the springs
« Reply #20 on: February 28, 2016, 09:10:53 am »
well yeah
It might be the shocks. But they are Billstein Nitro Drop 2s... Should work fine with this setup. Had the same setup on my 82 with a Big Block and had more travel than I do now. I'm working on it in a few and will let you know what I found. Then again the more I think about it I think it might be the 2" drop springs I put on it. Last truck I did I just cut a full coil out of the original springs. But today will be the first time I've touched it in wks due to working so much.
Thanks again and I will keep you all posted.
