Author Topic: 700R transmission  (Read 3361 times)
Offline 85ChevyRyder
700R transmission
« on: February 19, 2016, 04:23:48 pm »
Hello all! I have a 700R transmission with a 2800 stall that's having trouble getting into gear. I started it, backed it out the garage,  then back in. Waited a few minutes, started the truck again and now it will not get in gear. Transmission is full of fluid and not leaking. Any ideas on why it won't go into gear?
Thanks!
Offline Fairlane514
Re: 700R transmission
« Reply #1 on: February 19, 2016, 07:13:33 pm »
Is it a fresh rebuild?   Possible the linkage disconnected from the manual valve.
« Reply #2 on: February 19, 2016, 07:29:30 pm »
...or the link between the column and transmission is loose or separated?
Offline jg1977c20
« Reply #3 on: February 23, 2016, 02:47:15 am »
take the pressure line off at the cooler and get a bucket to catch the fluid -have a buddy start it up and see if you get good pressure - other than that the forward clutches are likely gone if has some miles on it
1977 c20 cheyenne camper special 8200gvw
