Author Topic: Fender Differences  (Read 10122 times)
Offline dixiepc
Fender Differences
« on: March 03, 2016, 06:44:28 pm »
Is the side marker lights the only difference between 79' fenders and 84' fenders.
I'm wanting to know so I can determine if I can use a 79' core support and grille with 84' fenders and hood.
Re: Fender Differences
« Reply #1 on: March 03, 2016, 06:59:51 pm »
73-80 are the same and here is where the design changes
81-86 (87-91 R/V) are the same
So no your 79 and 84 fenders are not interchangeable
Offline dixiepc
« Reply #2 on: March 03, 2016, 07:04:40 pm »
So the contours are different then.
Next question is can a 79' grille be made to work on a 84' core support?
Offline enaberif
« Reply #3 on: March 03, 2016, 07:16:47 pm »
Anything can be made to work. But if you mean using OEM parts then no.
Offline dixiepc
« Reply #4 on: March 03, 2016, 07:31:14 pm »
I am hoping that the 79' core support and grille can be made to work with the 84' fenders and hood.
« Reply #5 on: March 03, 2016, 08:07:30 pm »
73-80 from the firewall forward is different from 81 on. They do not interchange
Offline Engineer
« Reply #6 on: March 03, 2016, 08:08:53 pm »
It isn't possible without a massive rework of the profile of the front fenders.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline dixiepc
« Reply #7 on: March 03, 2016, 08:15:37 pm »
If I use everything 79' from the firewall forward, how will the 79' hood match up to the 84' tub?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #8 on: March 03, 2016, 08:33:02 pm »
You over on diesel place too?
Hood will work, need to use 79 wiper system and either cover or leave the hinge holes on the later tub
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
 1986 Chevy K30(under repair)
Offline dixiepc
« Reply #9 on: March 03, 2016, 08:48:09 pm »
Found me huh
