Author Topic: Np205 syncro question  (Read 6134 times)
Offline Big Daddy
« on: April 11, 2016, 04:22:36 pm »
82 k30 with syncro t/c. Did a complete tear down to replace seals and gaskets.
Noticed some wear and chipped gear on large idler gear. Replaced the idler assembly
with parts from another case but then I read somewhere that the idler is different
between syncro cases and non syncro cases. Is that true? If so, can I change front
output to non syncro (shift fork, rear cover, etc)
Offline Engineer
Re: Np205 syncro question
« Reply #1 on: April 12, 2016, 06:32:13 am »
Do they look physically the same? If so they should interchange. Ratios didn't change so tooth count shouldn't be an issue.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Big Daddy
« Reply #2 on: April 12, 2016, 05:59:55 pm »
guess Ill be shopping for a parts t/c
Offline Big Daddy
« Reply #3 on: April 16, 2016, 04:53:56 am »
Not to bad of a swap. Took about an 1 1/2 hours
Offline Engineer
« Reply #4 on: April 17, 2016, 06:11:29 am »
Good deal.
