Author Topic: How to put a bandaid on bad paint  (Read 10731 times)
Offline Woober
« on: April 16, 2016, 07:27:03 pm »
Short of a new paint job, is there anything I can put on the spots that have "popped?" It is an 87 with 2 tone grey and red; actually looks real nice when cleaned up, but the roof looks terrible. Just wondering what others do to fix this up.
Scott
Re: How to put a bandaid on bad paint
« Reply #1 on: April 16, 2016, 07:49:11 pm »
Popped as in exploded? pics?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: April 16, 2016, 10:03:29 pm »
Mask and respray the roof, sounds like a poor prep and oil was under the paint(or water)
Was it a diy job?
 1986 Chevy K30(under repair)
Offline Mike Phillips
« Reply #3 on: April 17, 2016, 06:24:50 am »
Scott
When you say "popped" do you mean the paint is flaking of?
Does the affected areas look like a bad rash?  If so, this is called clearcoat failure and there's really no way to fix it outside repainting the area.
Offline Woober
« Reply #4 on: April 20, 2016, 08:09:10 pm »
Stock paint job. You nailed it. Looks like a bad rash where big chunks have flaked off, right down to the metal.
Not knowing anything about auto paint, what kind of stuff would I need to fix up the "bad areas?"
I just really want to protect from rust.  Don't really care about looks.
Thanks for the feedback.
Scott
Offline LTZ C20
« Reply #5 on: April 21, 2016, 04:12:52 am »
Mask off the affected area, sand and repaint, that would be the easiest and smartest way to repair it.
« Last Edit: April 21, 2016, 09:42:34 pm by LTZ C20 »
LTZ Cheyenne C20
Offline DustyRusty
« Reply #6 on: April 21, 2016, 07:30:00 pm »
There are others with much more painting experience than I have but here's what I'd do:  If there are no rust-throughs, I'd sand to bare metal, apply Extend rust converter (aerosol or paint-on), prime, and then top coat.  That should protect the metal and be relatively inexpensive.
Hope this helps.
Rusty
Customized by rust.
