Author Topic: Help Me Pick a Drivetrain  (Read 16254 times)
Offline bryanedp9
« on: April 20, 2016, 04:53:03 pm »
Hey folks, I've currently got an '89 ton 3+3 dually after being out of the squarebody game for too long. I'd always wanted one of the crew cabs. I'll get pictures up later, but it's nothing too crazy.
Anyhow, it's got the TBI 454/400 with 4.10 gears I believe. I'm aiming to replace the standard bed with a utility bed and a slide-in camper. It is to be a travel unit, and I don't need any more power, but I'm considering economy.
The 454 as-is gets around 10mpg and I'm sure could do better with some TLC and the right conditions. However, I've been playing with the idea of a turbo 6.2 or 6.5 diesel swap. The motors can be had cheap (especially the 6.2) but needs some fortifying. As well, I'd want to avoid the electronic pump of later 6.5 motors. This is all just one avenue.
I'm thinking 15mpg is top-notch for a 454 with the right gearing, and the diesel could only do slightly better in such a loaded rig, maybe 20mpg.
So I'm thinking to focus on gearing first. NV4500, maybe even an NV5600.
Others might say to just regear the rear, but the TH400 is getting a little lazy and only has 3 speeds, ya know.
Curious what you'd do. I am perfectly happy taking the slow roads for economy as it is, but I'd like to have those extra gears, especially for lugging it up to 70mph.
So 5 or 6 speed? Diesel or gas? Can the gearing really save either one much?
Offline K20Detroit
Re: Help Me Pick a Drivetrain
« Reply #1 on: April 20, 2016, 08:06:38 pm »
Personally, I would go with a 6.2/700r4 combo.
I used to have a truck with a rebuilt 350 and th400.
Aside from the engine+trans, they were the same rig driveline wise.
Without even considering fuel economy;
My 6.2 has a much more useful torque and power curve. Power off the line is vastly improved.
The 6.2 feels much more refined. It's easier to start in cold weather, it runs much smoother, better throttle response.
My 6.2 is an '84 K20 with Silverado package and 700r4 trans. I average 19MPG on my 285/75/16 tires, though do a decent amount of city driving.  The low end grunt really helps in the city.
Offline roundhouse
« Reply #2 on: April 20, 2016, 09:41:20 pm »
A non turbo 6.2 in a six wheeler crew cab with a slide in camper is going to be dangerously underpowered
Offline K20Detroit
« Reply #3 on: April 21, 2016, 12:27:21 am »
He mentioned fortifying the 6.2, which would allow performance mods at the same time.
Single plane intake, exhaust, mildly turned up pump, and you'd already have a decent amount of power.
Even with an EGR intake, restrictive mufflers, and untouched pump; my 6.2 would give my old 350 a run for its money. The 350 was rebuilt, with dual exhaust, upgraded carb (don't remember specs), and all the usual things.
Offline bryanedp9
« Reply #4 on: April 21, 2016, 09:51:10 am »
Yeah I should mention that I would hope to turbo. Not much, but just to help climb and compensate for altitude. If done mildly and I keep my foot out of it, it could be beneficial for mpg as well.
Offline roundhouse
« Reply #5 on: April 23, 2016, 05:57:11 pm »
The mpg is good.   But 85 HP is not enough
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #6 on: April 23, 2016, 08:52:43 pm »
What? The 6.2 had 130 to 160hp, a 350 had 160 to 210. That's at best only a 30 hp difference, which is easily overcome with choice upgrades
 1986 Chevy K30(under repair)
Offline bryanedp9
« Reply #7 on: April 24, 2016, 02:38:41 am »
Yeah my Chevette can make nearly 85hp lol
Oh also, I own a Chevette :/  I don't mind slow, I suppose.
That all said, you're right about the 350, Kaiser, but I'd be giving up a 454. The numbers don't look great, but a 5mpg increase with less than a grand in the motor ain't so bad, either.
EDIT: I guess I should add that, with the 6.5 Detroit in ideal spec I should be able to make 215hp and 440ft lbs whereas the 454 in it should've been about 230hp/385ft lbs from the factory.
I'm still keeping my eyes open for a 6.5
« Last Edit: April 24, 2016, 06:36:19 pm by bryanedp9 »
Offline roundhouse
« Reply #8 on: April 24, 2016, 09:50:47 pm »
Had 130 at best when it was brand new
An old one has about 85
I feel confident in claiming that the one that's in my 82 long bed hasn't made more than about 80-85HP since Reagan was in office
Offline square81
« Reply #9 on: April 25, 2016, 08:05:02 pm »
I'd give the 454 a little more power because you already have that. Either change the gears to 3.73 and keep the turbo 400 or add a good overdrive 4l80 or get a 5 speed and keep the 4.10s.
Offline bryanedp9
« Reply #10 on: April 28, 2016, 11:14:38 pm »
Noted, but that's kinda the antithesis to what I'm after. I'm willing to give up a little umph for 5mpg. Seems like regardless of gearing I'd be very lucky to get 15mpg from the 454.
Offline bryanedp9
« Reply #11 on: May 08, 2016, 10:16:53 pm »
So I've got a line on a '01 Dodge NV4500 2WD. Gotta see what it would take to swap behind the 454. Anybody know?
Offline big_al273
« Reply #12 on: May 08, 2016, 11:43:12 pm »
you would need to swap out the input shaft and bell housing for the Chevy versions, then you would have to figure out the speedo situation as the NV4500 has no provision for a speedo cable, if you had 4wd then this would be a non-issue as the speedo cable comes from the transfer case. oh and you would have drive shaft modifications and clutch pedal assemblies to find
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline bryanedp9
« Reply #13 on: May 09, 2016, 01:25:58 am »
I knew it being a cummins meant the input shaft was too big. Am I just looking for the SM bellhousing and Chevy input shaft and retainer? I figure the Dodge shaft for gas NV's is still an inch too long for a GM bellhousing, right?
Regarding the speedo, I think there's certain Dodge units with a mechanical speedo. This will be a bit of a problem otherwise. Seems pre-97 Dodge stuff had a mechanical speedo in the tail housing. I think I can swap the VSS for that, but it will still need the right gear and cable.
« Last Edit: May 09, 2016, 01:49:39 am by bryanedp9 »
Offline big_al273
« Reply #14 on: May 09, 2016, 06:32:38 pm »
You need the GM NV4500 bell housing and hydraulic clutch, NOT an SM456 bell housing (SM456 bell housings can be modified to work with some NV4500s not all) and a GM NV4500 input shaft. I have never heard of, or or seen a NV4500 with a mechanical speedo cable provision. Personally i would forget the Dodge NV4500 and find a GM NV4500 for what you want to do it would be a whole lot less effort than finding the parts to convert Dodge to GM. I have no choice but too make a hybrid GM/Dodge NV4500 for my Cummins swap, Dodge input and bellhousing GM output and tail housing
