Author Topic: nv4500 length  (Read 7325 times)
nv4500 length
« on: April 27, 2016, 06:17:41 pm »
looking for the length of the nv4500 including the bell housing. im putting a 205 on the back of it so if you have that measurement that would be good or whatever you can help with
Re: nv4500 length
« Reply #1 on: April 27, 2016, 06:28:28 pm »
think i found it but from the bell housing to the front of the 205 would be 26.5". anyone verify?
Re: nv4500 length
« Reply #2 on: April 27, 2016, 08:34:55 pm »
just had someone measure theirs.
Total length is 29 inches
Bell housing is 6 7/8 inch
Trans is 20 3/4 inch
Adapter is 1 11/16 inch
now this is with a 1 11/16 adapter thats required to mate a long input shaft 32 spline 205 with a round pattern (86+) to the nv4500.
Offline Displaced_Txn
Re: nv4500 length
« Reply #3 on: April 27, 2016, 08:56:16 pm »
i could measure mine but i have the adapter for the 208 on it.
Re: nv4500 length
« Reply #4 on: April 27, 2016, 09:30:34 pm »
if you want you could double check it all to the front of the adapter. i trust where these numbers came from but i had found another place that said the 4500 was only 12"
Re: nv4500 length
« Reply #5 on: April 27, 2016, 11:03:33 pm »
ill check it in the am, and i know its def not 12" long
Offline Bunkerbuilder
  • OldManOfTheSea.
Re: nv4500 length
« Reply #6 on: April 28, 2016, 12:18:39 am »
Irish I'll give you the dimensions of mine in the am.
I do know from recently measuring the AA bellhousing I had but recently returned to AA was 6.625 inches.
Anything longer then about 6.200 with the 1.250 10 input shafts that's on my 2001 NV4500.
AA had a extra long pilot bearing  that extended well past the std location that the factory pilot bushing would sit at on the crankshaft.
My nv4500 body is 12.250 long and the tail housing is 7.875.
Didn't measure the square donut as it wasn't where the transmission was, will get that info later if you need it.
« Last Edit: April 28, 2016, 01:16:37 pm by Bunkerbuilder »
2007 Chevrolet Silverado K3500
1984 M1028 496,NV4500,NP205.
1986 M1008 6.2L,THM400,NP205. < Was T boned totalled by ins co, parting out.
1986 M1031 MTY DRIVETRAIN
