Author Topic: HYDRAULIC CLUTCH  (Read 10805 times)
Offline CHUCK41
  • Newbi I want to say hello to everyone
HYDRAULIC CLUTCH
« on: May 12, 2016, 09:52:29 pm »
 I have a 1987 GMC  V1500 350. 4speed Muncie SM465 transmission, it has a
 11 inch hydraulic clutch,  the flywheel, clutch disc, pressure plate, throw-out
 bearing, were new in 2011 the truck did not move with it`s engine until last
Monday May 9th I put on a new clutch master cylinder, slave cylinder and line.
I have one inch of travel on the slave cylinder rod.is that enough ? is there more
then one slave cylinder for this truck?    THANKS  CHUCK41
        don`t know why half my post got lost
« Last Edit: May 13, 2016, 09:24:19 am by CHUCK41 »
CHUCK41
Re: NYDRAULIC CLUTCH
« Reply #1 on: May 12, 2016, 10:21:20 pm »
what are you asking? or telling?
Offline CHUCK41
« Reply #2 on: May 12, 2016, 11:08:43 pm »
I`m telling you what  I have and what has been done and what is happening, and I appreciate
any help .        CHUCK41
CHUCK41
« Reply #3 on: May 13, 2016, 05:03:00 am »
" I have a 1987 GMC  V1500 350. 4speed Muncie SM465 transmission, it has a
 bearing, were new in 2011 the truck did not move with it`s engine until last "
Okay?
This makes no sense as a question.
Is there a question hidden in here?
Offline roundhouse
« Reply #4 on: May 13, 2016, 08:38:31 am »
You Gotta finish the question
Offline CHUCK41
« Reply #5 on: May 13, 2016, 09:03:54 am »
 :-[What could be wrong? could I  have the wrong slave cylinder? is there more then one for this truck?  is one inch of travel enough for the rod on the slave cylinder?  THANKS CHUCK41
CHUCK41
« Reply #6 on: May 13, 2016, 09:08:36 am »
What is exactly the issue.  Does the clutch not press in enough to dis-engage?
Offline CHUCK41
Re: HYDRAULIC CLUTCH
« Reply #7 on: May 13, 2016, 09:35:22 am »
Is one inch of travel on the slave cylinder rod  enough to release the clutch?   CHUCK41
« Last Edit: May 13, 2016, 03:56:06 pm by CHUCK41 »
CHUCK41
Offline roundhouse
« Reply #8 on: May 14, 2016, 09:40:10 am »
Should be
Is it not releasing ?
These are very hard to bleed but if you're seeing one inch of movement that should work
Offline CHUCK41
« Reply #9 on: May 14, 2016, 07:45:57 pm »
ROUNDHOUSE  THANK YOU
The clutch is not releasing, is there more then one slave cylinder for this truck? Last week I put
on a new clutch master cylinder, slave cylinder and line. The pressure plate, disc and throw-out
bearing were bought sometime between 2001 and 2011, when the engine was put back in the
truck. Last Monday was the first time it moved  by it`s engine sjnce  2001. I don`t   know if
any of the clutch parts are right. I`m thinking of pulling the engine and putting in a new clutch.
                                            THANK KOU   CHUCK41
CHUCK41
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #10 on: May 14, 2016, 10:25:57 pm »
Is the fork seated all the way, and did you make sure the throwout bearing was properly installed?
 1986 Chevy K30(under repair)
Offline CHUCK41
« Reply #11 on: May 15, 2016, 10:59:51 am »
1967KaiserM715  THANK YOU
 It`s put together right but I don`t know if the clutch parts are right, and I don`t know if I
have the right clutch fork, ball stud or throw-out bearing.  It`s been apart so long I`m not sure any of the parts are right. I think the only thing I can do now is pull it down and put in what I know are the new right parts.
                       THANK  YOU   CHUCK41
CHUCK41
« Reply #12 on: May 15, 2016, 12:40:14 pm »
I know when I threw my bellhousing on the fork felt weird (new fork and ball stud), turns out one of the spring clips that goes around the stud wasn't seated right, giving a lot of play in the fork, without putting pressure to the clutch
Sent from my LGL34C using Tapatalk
Offline CHUCK41
« Reply #13 on: May 15, 2016, 04:10:28 pm »
 I`ll check that,  it will be the next thing I do            THANKS AGAIN  CHUCK41
CHUCK41
« Reply #14 on: May 15, 2016, 06:26:09 pm »
Sounds like you have air in the system.
