Author Topic: 87 suburban tbi idle surge  (Read 4895 times)
Offline Charlieam
« on: May 14, 2016, 08:14:08 pm »
Picked the truck up last week, did half a tune up on it today, plugs, wires , cap rotor, check engine light comes on erratically. Haven't pulled codes or changed fuel filter, drove it 300 miles home when I picked it up. On throttle tip in it Loozes power and runs like poop intermittently. When I did plugs today I noticed a broken connector, it goes to nowhere. here is a pic. What's the next thing I should look at
Thanks!
« Last Edit: May 18, 2016, 01:05:24 pm by Irish_Alley »
Offline frotosride
    • WFO CONCEPTS
Re: 87 suburban tbi idle surge
« Reply #1 on: May 14, 2016, 10:05:38 pm »
Check all of your sensors that the ECM needs to make sure they are there and connected as well as the ones for spark control.
Tps, Iac, temp, o2, knock sensor, etc...
As far as the connector just solely based on location it could be for the A/C clutch that seems to be missing  (?)
Offline Charlieam
« Reply #2 on: May 14, 2016, 10:56:15 pm »
A/c compressor is there, everything else seems to be plugged in, I found article on codes so I'll pull them tomorrow.
What is the module to right of tbi unit? It has one corroded terminal
Offline roundhouse
« Reply #3 on: May 15, 2016, 06:40:27 am »
Surging usually indicates a vacuum leak
Offline Charlieam
« Reply #4 on: May 15, 2016, 08:03:58 am »
I'll check for vac leak also, that would make sense with tip in stumble
Offline Captain Swampy
  • Wisconsin
« Reply #5 on: May 21, 2016, 02:53:06 pm »
That looks like it might belong to the IAC solenoid.
