Author Topic: Wheel Bolt Pattern 77 Chevy pickup  (Read 12448 times)
Offline Fulltimechevy89
« on: May 24, 2016, 10:18:16 pm »
Hi!
Can anyone tell me if the 1/2 ton 1977 k10 chevy truck originally came with 5 or 6 bolt wheels. I've been told that I have the axles off a 72 4x4 truck.
Thanks!
Offline blazer74
« Reply #1 on: May 25, 2016, 12:51:35 am »
1/2 ton K10 4x4's are 6 lugs including the K5 Blazers
http://www.crawlpedia.com/bolt_patterns.htm
« Last Edit: May 25, 2016, 03:00:04 am by blazer74 »
Offline Austin4wd
Re: Wheel Bolt Pattern 77 Chevy pickup
« Reply #2 on: May 25, 2016, 11:31:24 am »
Okay GM is really easy. All rims have the same bolt pattern from '71 until the mid '90s.
1/2 2wd: 5 bolts
1/2 4wd: 6 bolts
3/4 ton and 1 ton, 2wd or 4wd, 8 bolts
Hope this helps!! :)
'88 K5 Blazer (daily)
'80 K10 Sierra Grande (restoration)
'80 K20 Sierra Grande (Duramax swap0
'93 C10 Silverado (future build)
'90 Cavalier (RWD SBC swap in mind)
« Reply #4 on: May 26, 2016, 10:08:20 pm »
Thanks for the info. Sure did help me out. Some brake parts were for my truck but came with 5 pattern instead of six. I think i have swapped axles on mine truck but the wheels must be the same.
Thanks again!
