Author Topic: Blowing Fuses....Help!  (Read 3688 times)
Offline Allblackcars
« on: May 29, 2016, 06:52:13 am »
When I hit my brakes I hear a pop from the fuse panel area. I have tail lights but no brake lights.
This issue continued for a couple days and then I noticed my right turn signal dash light not blinking.
I started tampering with the turn signal stalk and then it will blow the turn signal fuses when I put right turn signal on, only....
So the brake light fuse was the first issue
Right turn signal became the second...Not sure if it's related
1986 Silverado
« Last Edit: May 29, 2016, 07:02:24 am by Allblackcars »
Re: Blowing Fuses....Help!
« Reply #1 on: May 29, 2016, 08:37:13 am »
Go to the right rear tail light and remove inspect the bulb, socket and related wiring.
« Reply #2 on: May 29, 2016, 11:01:42 am »
I pulled the lens and then the assembly... Didn't see anything noticeable. Cleaned spade that clamps onto assembly... Wires dusty but nothing frayed...
« Last Edit: May 29, 2016, 11:03:14 am by Allblackcars »
« Reply #3 on: June 16, 2016, 10:23:40 pm »
 Update: dead short where wiring got onto exhaust after c- notch in rear....All problems resolved
