Author Topic: Quadrajet 17085226  (Read 6014 times)
Offline Fourxbob
Quadrajet 17085226
« on: June 11, 2016, 06:54:14 am »
The two holes for the set screws in baseplate are stripped. Will the baseplate off of a different quadrjet work?
Offline Fourxbob
Re: Quadrajet 17085226
« Reply #1 on: June 11, 2016, 08:47:31 am »
Have a Rochester quadrajet 17085226 with the baseplate stripped for idle set screws. Can I use a baseplate off of a different carb other than the 17085226??
Offline Stewart G Griffin
« Reply #2 on: June 11, 2016, 11:48:27 am »
Hold on--- getting lunch.
« Reply #3 on: June 11, 2016, 01:02:08 pm »
You could but if the idle passages, vacuum passages etc. don't match then it probably won't work very good.
« Reply #4 on: June 11, 2016, 01:31:19 pm »
i hear it's an easy repair for the idle mix screw holes.
May want to go over to Cliff's quadrajet forum:
http://www.cliffshighperformance.com/
Offline Fourxbob
« Reply #5 on: June 11, 2016, 09:08:32 pm »
Got a carb off of a 1979.  baseplate looks identical to mine. No difference at all. Now it seems the valves are stuck shut on the one I just picked up. Got it soaking in penetrating oil. Fingers crossed.
« Last Edit: June 11, 2016, 09:24:32 pm by Fourxbob »
Offline blazer74
« Reply #6 on: June 12, 2016, 11:28:11 pm »
Could be the same. Bypass air passages might be different size.
Also the vacuum Ports may be different.
Be careful with the frozen linkage, the shafts easily bend.
Offline Fourxbob
« Reply #7 on: June 28, 2016, 07:05:01 pm »
Got it together. A little grinding on the front passenger side of carb where it was indented for throttle body. But other than that it worked out well. Thànx for the input.
Sent from my XT1526 using Tapatalk
