Author Topic: Heads cam intake and carb?  (Read 4079 times)
Offline Jakethesnake73
« on: June 24, 2016, 10:07:34 pm »
My valve guides are going bad so i might as well upgrade. I have 600 cfm edlebrock i think what would be the best cam heads and intake. Id want a roller cam for sure. I just want a little more punch and hopefully some tire squeal ehen i mash the throttle down
Sent from my SAMSUNG-SM-G891A using Tapatalk
« Last Edit: June 25, 2016, 06:51:02 pm by Jakethesnake73 »
Re: Heads cam intake and carb?
« Reply #1 on: June 25, 2016, 01:01:04 pm »
what are we working on?
600 cfm should be good enough unless you plan on turning 6000 rpms
the cam and intake should be in the same rpm range. i cant tell you which one to get ill let rich or someone else tell you
« Reply #2 on: June 25, 2016, 06:50:39 pm »
73 k10 with a 350
