Author Topic: Open air filter  (Read 3156 times)
Offline Stm3784
Open air filter
« on: June 25, 2016, 07:19:08 pm »
Hi guys, I got a stock 350 2 barrel. Im considering putting an open air filter on. What are everybody thoughts on open air vs. snorkel housing. 1978 k/20 350 sm465 np205.
Offline Jakethesnake73
Re: Open air filter
« Reply #1 on: June 25, 2016, 11:08:39 pm »
Should add a little more flow. They look good untill the filter gets dirty which will happen quick with the open air filter
Sent from my SAMSUNG-SM-G891A using Tapatalk
Offline Stewart G Griffin
Re: Open air filter
« Reply #2 on: June 26, 2016, 08:31:29 am »
1) If you still have the plastic tube running from the front of the truck still hooked up to the snorkel, then little if any advantage to running open element.   And very possibly a drop in mpg.     And if you do get any advantage it would only be at like 4500rpm and higher.
2) If you do not have the tube hooked up then very little advantage and if any advantage then only at 4000rpm or higher AND it totally depends on the brand of the open element.   Also depends on height---taller is better.
Remember, just my opinion.  i do not have any tests to back this up.
i'm running an open element (soon to be K+N) because it's too much of a hassle getting the stock air filter housing to fit after the swap.
