Author Topic: Driveline Vibration  (Read 97330 times)
Offline philo_beddoe
  • 77 C-10
Re: Driveline Vibration
« Reply #60 on: October 04, 2016, 05:17:48 pm »
when driving down the road at 50, and then quickly drop in neutral, the vibe goes away quickly. would anyone say no way it could be torque converter? ya know, the only thing left is something in the rear diff. maybe over the course of my life i'll just start replacing part after part until i nail it.
« Reply #61 on: October 05, 2016, 02:33:31 am »
since its not rpm related i wouldnt think the TC would be a issue. it has to be from the trans back to the tires. if you rotated the tires and the vib didnt change then i would think the rear. or even the drums???
« Last Edit: October 05, 2016, 02:35:29 am by Irish_Alley »
  • 77 C-10
« Reply #62 on: October 05, 2016, 07:29:52 am »
I agree from the tranny back. I am also noticing when going down the hwy at say 50, then drop in neutral and back in drive, it somewhat goes away a little. I sure would love just to try another tranny...just to see what happens.
« Reply #63 on: October 05, 2016, 08:30:50 am »
Have you rotated the tires front to back?
  • 77 C-10
« Reply #64 on: October 05, 2016, 12:26:04 pm »
Yes.
Offline MrFiveOh
  • The Local Po-Po
« Reply #65 on: October 05, 2016, 01:02:27 pm »
Double check your Trans Mount, I was told by Firestone it was good. I looked myself and and found out it was  crumbling.....
1974 C-10 AKA "Smurf"
  • 77 C-10
« Reply #66 on: October 05, 2016, 02:48:35 pm »
Just replaced last spring, brand new. Oh how i wish it was that !
Offline MrFiveOh
  • The Local Po-Po
« Reply #67 on: October 05, 2016, 03:49:57 pm »
Just cause its new doesn't mean its good......
  • 77 C-10
Driveline Vibration
« Reply #68 on: October 05, 2016, 04:09:20 pm »
Yah, but not a complicated part, just a block of rubber, basically.
« Last Edit: October 05, 2016, 04:51:50 pm by philo_beddoe »
Offline Rattler12
  • Old Geezer
« Reply #69 on: October 05, 2016, 09:34:14 pm »
If it goes away after putting in neutral at 50 mph it's not your rear tires, wheels, rear end nor drive shaft as they are all still turning at close to the rate they were at 50. I'd say its in the trans or motor and probably  the motor since putting it in neutral at 50 mph reduces your rpms to idle and the vibration isn't present at idle whether standing still or coasting at 50 mph...jm2c's
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #70 on: October 06, 2016, 02:58:06 am »
I've had CV axles only vib when under throttle. Still there when you lift off but hardly noticeable. Have you took the rear cover off the differential? I would if you haven't and see if you see big metallic parts just sitting on the bottom.
  • 77 C-10
Driveline Vibration
« Reply #71 on: October 07, 2016, 07:39:07 am »
Definetly something that turns/rotates. I will look into the rear diff., a while back i did change rear diff oil. I would like to check it again. I have to let  Vile Z. determine if any problem in rear diff though. I cannot move driveshaft in any way, no loose play at all. My tranny guy said there is really nothing in there that would cause it. Besides, why sometimes can i almost totally not feel it. I think i need to rule out rear diff and rear axle. That will tell me a lot.
Offline jg1977c20
Re: Should this do this?
« Reply #72 on: October 07, 2016, 07:19:26 pm »
How tight are your exhaust system hangers?
i was just going to say ................ check the exhaust - i have flowmaster 40,s on and they give of some weird vibes going to lose those real soon . but i had to place pieces of rubber where the hangers attach to keep the reverberation down .
1977 c20 cheyenne camper special 8200gvw
  • 77 C-10
« Reply #73 on: October 11, 2016, 09:26:07 am »
I really wonder if it could be coming from the tranny somehow. Is it possible??
It is NOT consistant, sometimes pulsating, sometimes steady, and sometimes is is really light and hard to detect.
  • 77 C-10
Driveline Vibration
« Reply #74 on: October 11, 2016, 11:03:05 am »
https://vimeo.com/162083848
Nope, not tranny. Just went to a solid tranny shop and showed them the video here, he said that is way too much play. Thats my problem. Does anyone agree from the video.
But this is what Vile posted, so i dont know.
https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fforum%2E73-87chevytrucks%2Ecom%2Fsmforum%2Findex%2Ephp%3Ftopic%3D32734%2Emsg280084%23msg280084&share_tid=32734&share_fid=15802&share_type=t&share_pid=280084
But i am starting to believe it is nothing between the grille and rear U-joint.
« Last Edit: October 11, 2016, 11:12:04 am by philo_beddoe »
