Author Topic: Rochester QuadraJet  (Read 5661 times)
Offline Shaker
Rochester QuadraJet
« on: July 30, 2016, 12:12:09 pm »
Hey,
I`m looking for an Air cleaner for my Quadrajet Carb. Oh and just a cheap one, Something more appealing than the stock housing. The engine is not strong and is going to be swapped out down the road but I thought what the heck there has to be some cheap no name air cleaner housing out there. Something like the attached photo chrome or black does not matter to me.
I know I have to get a crankcase breather as well for the valve cover.
If someone one knows a link or part number that I could just order it up over the interweb that would be great  ;)
Cheers
1986 C10, 305, Auto 700R4, 2wd, Rochester Quadrajet, Full Length Headers, Dual Exhaust
Offline Stewart G Griffin
Re: Rochester QuadraJet
« Reply #1 on: July 30, 2016, 01:59:49 pm »
Mr. Gasket 1487 is $20.  Proform 9" is even cheaper.
But since you have a v-8 you can go much larger diameter.  i went with the 1487 because i needed the truck running asap, did not have enough clearance for anything larger than 9" (v-6 throttle bracket is in the way) and the local autoparts store had it on the shelf.
After it clogs, i'm going with K+N.
« Reply #2 on: July 30, 2016, 02:41:24 pm »
depending on how cold it gets in the winter you may want to keep the stock air cleaner. theres a post about how and why you might run into trouble with keeping the engine properly tuned when it gets colder
Offline Shaker
« Reply #3 on: July 30, 2016, 02:49:50 pm »
Motor wont ever see a real winter. I`m living on the West Coast of British Columbia,Canada and it barely drops below 0 degrees Celsius the area I`m in.  So no worries on engine performance plus its an old worn out temporary engine.
I`ll check out the Mr.Gasket one.
« Reply #4 on: July 30, 2016, 09:13:43 pm »
0° C is still 32°F you can have problems at 40°
heres one. i know theres another
http://forum.73-87chevytrucks.com/smforum/index.php?topic=27239.msg226597#msg226597
