Author Topic: 76MM TURBO 5.3  (Read 5804 times)
Offline Chappo
  • It is what It is...
76MM TURBO 5.3
« on: July 31, 2016, 05:27:13 pm »
I have my build, on another post and though I would put an update of my turbo upgrade.
First off this is not a bolt on turbo kit, this kit was built by my good buddy Mic Hubble, known as TurboMic.
And was tuned by Alan at Nelson Performance.
I only told him where I wanted the turbo at and supplied him parts.
I did the wideband gauge install and boost gauge install.
I did leave my 224r cam as i don't plan on running over 15 lbs of boost.
The turbo setup is a On3 76mm unit, blow off and wastegate.
Price for build was right at 3k, so its a very doable project and can be done cheaper if you have extra turbo parts lying around.
Truck manifold was used on passenger side, and custom manifold for drivers to clear a/c.
I didn't have a/c I could have gone with dirty dingo kit.
I don't have the dyno sheet but the truck made 500\500 on 5 lbs of boost, it is currently running 8 lbs.
http://
http://
« Last Edit: August 01, 2016, 06:02:34 am by Chappo »
If you want what everyone else has do what everyone else does, If you want what no one has do what no one does..
Offline redhot1.4
Re: 76MM TURBO 5.3
« Reply #1 on: September 26, 2016, 08:37:03 pm »
Super clean job man.. looks like something out of a dream
Sent from my SAMSUNG-SM-G870A using Tapatalk
