Author Topic: high beam, turn signal, ignition issues  (Read 4176 times)
Offline mike9274
« on: August 01, 2016, 01:59:55 pm »
Hi, guys. New to the group.
The issue I'm having is this...
On my 1986 chevy K10 Suburban, when I turn on high beams, all the lights go out. I replaced the headlight switch, but it didn't fix the problem. I ran a hot wire to the low beam side of the lights from a switch to get the lights to work. Funny thing is, the low beams would work with the light switch until you turned the high beams on, then you would have to use the bypass switch to get the lights to work again.
I have since replaced the turn signal switch, the dimmer switch, and the steering column, but the issue is still there. After replacing the turn signal switch, the lights and turn signals worked until i hit the high beams. I had the truck running while i was testing the lights, but the high beams killed everything. Now the truck won't start at all.
All the fusible links ohm out good, I have power to the starter,alternator, juntion terminal, and at the harness going into the cab.
 I also jumped the wiring for high/low beam... both those circuts work good.
I tested for voltage at the fuse box, but on the fuses for turn/back up, ignition,and guage/idle, I have 0.08 volts.
I have looked at the scematic on this site, but I can't seem to find what wire powers these circuts.
Short of hot wiring everything to get it going, what can I do?
ANY IDEAS? I'm at a dead end.
Offline hatzie
Re: high beam, turn signal, ignition issues
« Reply #1 on: August 01, 2016, 03:03:44 pm »
You probably have a short in the HI beam wires.
I assume you re-tested the fusible link at the starter that feeds the headlamps along with the other fusible links.
Offline Chuck Step-a-side
« Reply #2 on: August 01, 2016, 06:57:42 pm »
Like the first poster, it seems you have lost a ground or fusable link. Rule number one - don't bypass by adding switches or wires to make it work. This will create other problems on top of what is already wrong. I would go through all your connections at the steering column one by one and make sure all connectors are aligned and seated properly. Try locating the checking the mentioned fusable link for a short and then check the two ground wires for the headlight circuit in front of the engine compartment by the left and right headlights and check for loose connections. Another thing to try - take apart the bulkhead connectors at the driver side engine firewall compartment and carefully separate the headlight bulk connection and put aside. The reconnect the main bulkhead connectors and try starting your engine. If this works, then your headlight wiring is the problem. Take pictures of everything you touch to help you re-install properly. Good luck.
