Author Topic: MPG, Part 2  (Read 105084 times)
Offline Stewart G Griffin
MPG, Part 2
« on: August 27, 2016, 12:07:09 pm »
320.6 miles / 17.010 gallons = 18.85 mpg
$2.199 per gallon regular at exxon,  $37.40 to fillup
Now that's more like it.  Not all highway miles either.   i still think there is plenty of room for carb tweeking.  Runs ok though.
New setup:
GM reman 4.3 v-6  LB4  roller lifters, 9:1 compression
Jeg's reman quadrajet #15805
TH-350C trans
2.56 rear gear
235/75-15  Hankook Optimo 727's
Single stock exhaust---stock exhaust Y then rest of exhaust cobbled together with flexpipe and stock type muffler.
Re: MPG, Part 2
« Reply #1 on: August 27, 2016, 01:13:16 pm »
do you have a fan on it this time?
Re: MPG, Part 2
« Reply #2 on: August 27, 2016, 05:40:09 pm »
Yes, definitely----a 14" Spal electric.
« Last Edit: August 28, 2016, 04:28:07 pm by Stewart G Griffin »
Offline redhot1.4
Re: MPG, Part 2
« Reply #3 on: August 28, 2016, 05:46:29 pm »
My goal is to get my 78 to at least 16mpg.im currently best at 11 mpg. .. Is it possible I have a 350 with a th350 1,2&drive lol
My next upgrade is electric fans
Sent from my SAMSUNG-SM-G870A using Tapatalk
Re: MPG, Part 2
« Reply #4 on: August 28, 2016, 06:48:52 pm »
i think it's possible, but tell us more.   Also, i don't think electric fans are going to make that much a difference if any, UNLESS you have a fixed fan.   The only reason why i went with electric was to save space and it's not easy to find a shroud for my application.
« Last Edit: September 22, 2016, 08:41:32 pm by Stewart G Griffin »
Offline redhot1.4
Re: MPG, Part 2
« Reply #5 on: August 28, 2016, 06:51:43 pm »
Plain 350. With the new eps edelbrock performer intake manifold and new 600cfm edelbrock carburetor headers dual exhaust
Re: MPG, Part 2
« Reply #6 on: September 06, 2016, 09:49:55 pm »
What differential gear do you have?
275.7 miles / 17.945 gallons = 15.36 mpg
$2.119 per gallon regular at Shell, $38.03 to fillup
It turns out the choke was not adjusted properly as i had previously thought;  It would get stuck on low-mid step for too long and not go down to curb idle for a good 10-15 mins.   i did not really notice this for the previous tankful because it was mostly highway driving.
Also my tires were pretty low.  My other inflator broke, so i got another one.
So hopefully, the next tank will be better.
Offline redhot1.4
Re: MPG, Part 2
« Reply #7 on: September 06, 2016, 10:04:15 pm »
Gears I don't really know.  I'm running a 285 75 16 tires.  It's a tall tire. I wanna say at 26 2700rpm I'm going 70mph
I was trying to up the rear end with a tall tire. I'm driving 56 miles round trip on the old truck all highway with a total of 3 stop signs and 2 red lights total.
Re: MPG, Part 2
« Reply #8 on: September 13, 2016, 07:51:58 pm »
322.6 miles / 18.232 gallons = 17.69 mpg
$2.559 per gallon v-tech (premium) at shell.  $46.66 to fillup
i accidentally pushed the v-tec (premium) button at the pump because i'm not use to filling up at Shell.  i normally get regular.
Lots of idling this time;  The traffic situation around here just is not working out anymore.  :(
Got the choke adjusted right.  Engine runs better than ever.
« Last Edit: September 13, 2016, 08:01:50 pm by Stewart G Griffin »
Re: MPG, Part 2
« Reply #9 on: September 13, 2016, 10:21:11 pm »
not to shabby for a bunch of slow traffic
Re: MPG, Part 2
« Reply #10 on: September 13, 2016, 10:24:07 pm »
If you ever need a trans go to a 700R4.  1st. gear would be easier to get the truck moving requiring less throttle.  OD may never be needed unless you hit 85
Offline LTZ C20
Re: MPG, Part 2
« Reply #11 on: September 13, 2016, 10:36:11 pm »
85! With a 700, you can go 35 in OD, you can go 40, 45 in OD and lock up. Some even go into lock up in 3rd.
LTZ Cheyenne C20
Re: MPG, Part 2
« Reply #12 on: September 13, 2016, 10:44:25 pm »
He has a 2.56 rear.  Final drive would be 1.87... probably idle down the road at 45
Offline LTZ C20
Re: MPG, Part 2
« Reply #13 on: September 13, 2016, 10:52:21 pm »
Oh what a drag. In my opinion 3.73 and 4.10 gears are the only 2 worth using, they are the only 2 GM still puts in new trucks.
LTZ Cheyenne C20
Re: MPG, Part 2
« Reply #14 on: September 22, 2016, 08:46:16 pm »
326.3 miles / 16.736 gallons = 19.49 mpg
$2.259 per gallon regular at Exxon,  $37.81 to fillup
Even though there was much less idling this time, this might not be super accurate because i filled up at a different station---the previous two times was Shell and i normally use EXxon.   The pumps at shell are much slower and may allow more fuel to be pumped into the tank?
However, i do sense things are improving overall;  The engine continues to run smoother---i think it is still breaking in more.
