Author Topic: 4L60 Re-Rebuild for my C20  (Read 56433 times)
Offline LTZ C20
Re: 4L60 Re-Rebuild for my C20
« Reply #30 on: September 08, 2016, 12:36:39 pm »
I'll give Hughes a call then. BD, I already have a B&M cooler hooked up. It's all plumbed with steel hard lines and SAE hose rated for ATF. I use only Dexron VI ATF. Tho I am considering switching to the heavy duty Dex VI, only thing with that is that it is very expensive.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #31 on: September 08, 2016, 02:15:13 pm »
I just got off the phone with Hughes Performance. They recommended the GM22LXTM, which is the 1st of the 4 that I posted on page 2.
LTZ Cheyenne C20
« Reply #32 on: September 08, 2016, 02:42:14 pm »
with a 1800 stall???
« Reply #33 on: September 08, 2016, 02:42:31 pm »
do they offer anything lower?
Offline LTZ C20
« Reply #34 on: September 08, 2016, 03:16:27 pm »
Not sure. But that's what they said and I told him my cam specs, gears and tires.
LTZ Cheyenne C20
« Reply #35 on: September 08, 2016, 04:02:13 pm »
did you tell him about towing
« Reply #36 on: September 08, 2016, 05:11:37 pm »
Offline LTZ C20
« Reply #37 on: September 08, 2016, 05:50:31 pm »
LTZ Cheyenne C20
Offline LTZ C20
« Reply #38 on: September 08, 2016, 06:21:28 pm »
http://hughesperformance.com/xtm-xfm/
Looking at the GM chart, 700R4/4L60 30 spline options, the GM21LFUEL is a 1200 stall. The GM22LTOW is an 1800 stall. The GM22LXFM does not provide a stall rating and the GM22LXTM is an 1800 stall. All 4 models are between 350 and 400 bucks.
LTZ Cheyenne C20
« Reply #39 on: September 08, 2016, 06:31:45 pm »
I can't believe you had two "trans tech's" tell you it was fine to reuse the converter after a complete failure especially with a SRTA!
Offline LTZ C20
« Reply #40 on: September 08, 2016, 06:44:36 pm »
I think the reason they said that was because the fluid was perfect BUT the first guy said it's fine without actually seeing it as he now lives in Idaho. The second one said it is fine to reuse if you want too. Just the seal caused it to fail. But none the less, I'm going to replace it now and so far it appears that the Hughes GM22LXTM is my best option.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #41 on: September 08, 2016, 06:53:38 pm »
So the trans tech just told me he can get me a new converter for about 100 bucks. It is a PDQ brand, he said it was an HD version of the stock, it has a heavy duty reinforced bearing. Stall speed is 1200-1600.
LTZ Cheyenne C20
« Reply #42 on: September 08, 2016, 07:13:40 pm »
Based on what criteria?  Multiple part numbers?  Dependent on engine torque?  If one P/N ranges 1200 - 1600 RPM for a given application - that's not a big confidence builder!  LOL
Not knockin' it, just askin'.  lol
Offline LTZ C20
« Reply #43 on: September 08, 2016, 09:13:34 pm »
I asked him if that was the case. I assumed different part numbers as well. He said nope, one converter. I think it depends on available torque. That's all the info I could get. I tried searching the  PDQ website but I couldn't't find anything that matched the info I already had.
LTZ Cheyenne C20
Offline Rattler12
  • Old Geezer
« Reply #44 on: September 09, 2016, 08:16:21 am »
JMHO but your cam appears to be a little radical for a towing low torque producing engine. The LSA of 110 degrees is passing a lot of fuel mixture in and out until rpm rise makes everything catch up. The lumpity lump sounds great but kills low end
83 C-10 shorty 454, 5spd, 3:73 posi
