Author Topic: Emissions delete....heeeelllllppp  (Read 21319 times)
Offline SouthernBrandt75
Re: Emissions delete....heeeelllllppp
« Reply #15 on: September 14, 2016, 05:39:30 pm »
Thank you vile and zieg you guys have been awesome. Best forum ive been on so far. For anything not just Chevy trucks.  Thank you again
« Reply #16 on: June 03, 2017, 11:09:10 pm »
If you strip all of that off, do yourself and others put a quality set of headers and carefully remove it.  A lot of that is NLA and worth $ to someone needing to meet emission compliance.  Without it, it won't pass the sniff test because of no catalytic convertors
Hey there me again. So when i take the air pump off it seems to be that the belt only works it. is this correct? also yes i need headers i know. just a hard sale to the wife lol. Thank you in advance
Offline ehjorten
« Reply #17 on: June 06, 2017, 11:16:50 am »
If it is a 1-ton, 454, why does it have air or cats?!
-Erik-
Offline big_al273
« Reply #18 on: June 06, 2017, 08:12:44 pm »
Good question, last summer i looked at an 86 GMC C30 cab and chassis with the 454 and sm465 and it also had the air pump and lines into the manifolds. My guess would be that the emissions stuff was put on the trucks setup for unleaded gas as until 90 or 91(i believe, could've been later) you could order heavy trucks (10,001 lbs GVW and higher) with a Carb that was setup for leaded gas and I've seen an 88 square body cab n chassis with a factory carb in person so they did/do exist.
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #19 on: June 06, 2017, 10:17:18 pm »
cali trucks still had them. my 91 1 ton with a 350 had at least the cat. not sure about egr or air
Offline ehjorten
« Reply #20 on: June 07, 2017, 08:39:10 am »
Must be a Cali rig then.  My 1991 V3500 with the 454 did not have Cats and hence, no Air Injection.
-Erik-
« Reply #21 on: June 07, 2017, 02:57:59 pm »
yes still had the cali emissions sticker on it. i know it didnt have an air pump but i want to say it had an egr. or at least i think i would of noticed it missing. i know the exhaust shop didnt want to touch it cause i still had the cat in place when i told them i wanted to straight pipe it. i tried to tell them diesels back then didnt have cats but they said if it came from the factory like that they had to keep it.
Offline big_al273
« Reply #22 on: June 07, 2017, 10:41:12 pm »
i think it must be some other deciding factor because my 88 V30 1-ton crew cab with the TBI 454 IS NOT a California truck (came from Minnesota and may have been ordered through a government contract similar to the CUCV contract)  and it still has the air pump, egr and a cat on it.
Offline Dr_Snooz
« Reply #23 on: June 07, 2017, 11:13:27 pm »
My Cali '86 454, C-2500 has AIR, EGR and NO cats. If you can believe that.
« Reply #24 on: July 22, 2017, 07:43:07 pm »
Yup mine doesnt have the cats. And now it doesnt have any of that emissions crap..MMMUUUAAAHHAHAHAHAHA
Offline rameye
« Reply #25 on: August 01, 2017, 04:51:48 pm »
Im in a similar boat-- I was querying my local inspector/mechanic about my new wreck (1987 V-10) and he said in this area after 20 years there is no emission requirement, told me I could pretty much go hog wild. I did some searches on this board about removing the smog crap.
Still have some unanswered questions--
 If I go for some shorty headers with an 02 sensor bung welded in..will the computer post a code??
 Does the computer monitor the smog pump or anything else in the system??
 Any other pit falls??
 I plan on keeping the parts handy..got the belt situation figured out..  Im assuming the 02 sensor will tune the TBI accordingly
 Many Thanks
