Author Topic: 350 TBI Runs Rough  (Read 17516 times)
Offline jdusten
350 TBI Runs Rough
« on: September 21, 2016, 10:22:09 pm »
So I have an 87 Silverado half ton. 350 TBI with turbo 350 trans. It runs awful until up to operating temp and still lacks power then. it turns over for a few seconds, then has a fluctuating idle until warm, once put in gear the idle speed lowers (no tach so not sure on rpms) and taking off from a stop it bogs out, stalls, sputters etc. Its got a new fuel and air filters, plugs, wires, cap, rotor, IAC valve, MAP sensor, throttle position sensor, injectors, and fuel pressure regulator, and some new vacuum lines (not all of them have been replaced) I've turned many a wrench in my day but am no means a mechanic and this truck has got me pulling my hair out trying to get it to run right, Its straight piped and the exhaust ends about where the fuel doors are. Any help would be greatly appreciated!
Offline XrayTedd
Re: 350 TBI Runs Rough
« Reply #1 on: September 21, 2016, 11:09:04 pm »
Did you disconnect the esc before setting the timing? Check your fuel pressure and vacuum readings.
Sent from my SAMSUNG-SM-G900A using Tapatalk
"Till the wheels fall off"
« Reply #2 on: September 22, 2016, 12:25:26 pm »
http://www.73-87chevytrucks.com/techinfo/TroubleshootingTBISystems.pdf
for starters lets start with this
heres this
http://forum.73-87chevytrucks.com/smforum/index.php?topic=29996.0
for testing sensors. also check for vacuum leaks around the tbi base plate and the tbi itself and maybe unplug the egr vacuum to see if its stuck open
Offline Captain Swampy
  • Wisconsin
« Reply #3 on: September 22, 2016, 03:31:22 pm »
Could be the EGR valve. Bedazzled runs like crap when the EGR doesn't work.
Offline XrayTedd
« Reply #4 on: September 24, 2016, 12:34:54 am »
Any new updates on this?
« Reply #5 on: September 24, 2016, 08:47:00 am »
Check for vacuum leaks, check the TBI base gasket, make sure the map sensor hose is connected.
Offline Flyinhillbilly
« Reply #6 on: September 29, 2016, 06:39:50 pm »
You might try a coolant temp sensor. I've seen a lot of them go bad and cause the ECM to think the temp is -40 and that makes it dump the fuel to it.
I was born on a mountian, raised in a cave,
Overpowered cars is all I crave.
« Reply #7 on: September 29, 2016, 07:05:05 pm »
i would have to disagree and this is just my opinion. if the cts is reading cold it will default into a open loop where the settings are preset and dont depend on a sensor signal. once to operating temp the ecm changes setting depending on senor input, if it changes from open to closed then the cts should be working correctly but only a test on it would tell you either way. since it runs crappy all the time vacuum leak is the most plausible in my mind
« Reply #8 on: September 29, 2016, 09:37:12 pm »
I've been a professional mechanic for 20 years now, and I've seen this many times. The ECM just reads what the sensor tells it, it don't know good info from bad. TBI's were really crude.
« Reply #9 on: September 29, 2016, 09:56:16 pm »
well i worked at autozone for almost 2 years  8) lol. but no doubt the cts will cause it to run rough. seen one with a broken wire, would smoke real bad and run like crap and not go into closed loop. but since he says the performance changed once hes in closed loop i would think the cts is getting the correct signal to the ecm about the coolant temp. but this is all not worth discussing if he doesnt test the sensor or check for vacuum leaks
« Reply #10 on: September 29, 2016, 11:27:44 pm »
I'm thinking the 02 sensor is reading bad rich, and causing it to pull as much fuel as possible. I'm not sure about that part, but I've seen the CTS cause exactly what he's describing. Not saying that's for sure it, but for a $15 sensor that takes 5 minutes to put in, it's worth trying.
« Reply #11 on: September 30, 2016, 10:54:21 am »
Perform some basic checks before throwing parts at it...
You replaced the fuel pressure regulator, but did you actually check the fuel pressure with a manual gauge? ...Needs to be within the range: 10 - 15 PSI (~12 PSI is common).
