Author Topic: Holley 4 barrel to a 2barrel  (Read 5113 times)
Offline truckin2015
« on: October 04, 2016, 09:34:11 am »
I HAVE AN 86 C10 350/ 350 turbo transmission . The carburetor is a holley 4 barrel which uses way to much gas . Can I convert this carburetor to a 2 barrel ? If so how .
Offline truckin2015
Re: Holley 4 barrel to a 2barrel
« Reply #1 on: October 04, 2016, 01:02:50 pm »
1986 C10 Silverado
« Reply #2 on: October 04, 2016, 04:16:27 pm »
If you want to stay carbureted you should look into a quadrajet 4 barrel
Offline Stewart G Griffin
« Reply #3 on: October 04, 2016, 07:30:02 pm »
You could "convert" it to 2BBL by disconnecting the secondaries, but 4bbl to 2bbl has nothing to do with MPG (unless it's strictly a mechanical secondary carb, which i doubt)   What model holley DO you have?
2  four barrel carbs on an independent runner manifold could theoretically get as good if not better mpg than a single 4 barrel.
Rear axle ratio may be more important to mpg than carbs...
