Author Topic: Fan shroud  (Read 3561 times)
Offline Flangehead
Fan shroud
« on: October 06, 2016, 08:59:10 pm »
Hello,
I have a 1979 C10 custom deluxe with a 250 L6. I have a lead on an 87 Gmc 2500 with a 350 for parts. I was wondering of the fan shroud will fit on my 79 because I'm planning on putting in a sbc. Also, my truck has no power brakes but they are front disk. What would I need off the other truck besides the booster to convert it over ?
Thanks,
Bill
Offline NCali
Re: Fan shroud
« Reply #1 on: October 06, 2016, 10:12:17 pm »
the fan shroud should fit in there , thats easy to modify tho if it doesnt
The brakes : you will need the proportioning valve and the booster
Black Labs Matter
Online zieg85
Re: Fan shroud
« Reply #2 on: October 07, 2016, 07:26:23 am »
The proportioning valve you have should be fine just going with a power booster.  The master cylinder is different and you'll have to adjust your brake light switch as it will be closer to the floor.
Offline Flangehead
Re: Fan shroud
« Reply #3 on: October 07, 2016, 07:49:53 pm »
Thanks for the info guys. So get the whole booster AND master cylinder. I appreciate the help.
