Author Topic: Holley Sniper EFI Anyone  (Read 23253 times)
Offline swilliams
« on: October 17, 2016, 09:03:43 am »
Got home from work this morning and was met with a surprise.
« Last Edit: October 17, 2016, 12:53:42 pm by swilliams »
Offline Flyinhillbilly
Re: Holley Sniper EFI Anyone
« Reply #1 on: October 17, 2016, 05:30:25 pm »
I've installed one of the fast ezefi units. Looks to be about the same. EZEFI is awesome.
I was born on a mountian, raised in a cave,
Overpowered cars is all I crave.
Offline gwcrim
  • Far from a Newbie
« Reply #2 on: October 17, 2016, 08:16:06 pm »
Sweet!
Offline cvbear
« Reply #3 on: October 17, 2016, 08:41:12 pm »
I am looking forward to following this thread!  How are you going to deal with a fuel line return for the throttle body?
Offline swilliams
« Reply #4 on: October 17, 2016, 09:29:40 pm »
The stock 1986 C10 fuel pump has fuel, vent and return hard lines. Then i am going to use the FITech fuel command center for the high pressure side.
Offline swilliams
« Reply #5 on: October 18, 2016, 04:58:19 pm »
So after months of speculation turns out the the Sniper system does have timing control but i will have to either have to somehow lock my stock HEI distributor or go with an aftermarket distributor. In the instructions they use an MSD. For the lower end aftermarket EFI systems it has quite a few control options from multiple fans to A/C even nitrous.
Offline justin71105
« Reply #6 on: October 25, 2016, 01:11:42 am »
This is the one I have been eye balling lately:  http://fitechefi.com/products/30003/
1964 C10
Offline BlackTomC
« Reply #7 on: October 25, 2016, 10:03:43 am »
swilliams, you ever get this setup? Contemplating this for my 76 K25 Suburban party barge
The bottom line has dropped
Offline swilliams
« Reply #8 on: October 26, 2016, 02:44:23 pm »
I thought about the Fitech EFI but when i found out Holley was coming out with the Sniper system i decided to wait. I am going to use the: http://fitechefi.com/products/40003/
Offline swilliams
« Reply #9 on: October 26, 2016, 02:50:29 pm »
I am still waiting on parts. Now that I found out that the Sniper system has timing controls I am having to upgrade my distributor. When i get to the install i will post progress. I did do an unboxing video: https://www.youtube.com/watch?v=-lg3yOlyd3w
Offline Stewart G Griffin
« Reply #10 on: October 26, 2016, 03:55:29 pm »
Will this work on a 6 cylinder?
Offline swilliams
« Reply #11 on: October 26, 2016, 04:27:53 pm »
Holley says that it will with a  4 barrel square bore intake. Up to 650 HP.
Offline swilliams
« Reply #12 on: November 02, 2016, 05:23:33 pm »
Getting my parts gathered.
« Reply #13 on: November 03, 2016, 07:41:38 am »
how much $ and whats your current MPGs?
Offline swilliams
« Reply #14 on: November 03, 2016, 08:31:40 am »
Roughly $1600 for the setup i am going to run and for gas mileage i am running a Holley Demon 625 so i dont think it is over 9 MPG.
