Author Topic: 2" shackle and 2" hanger  (Read 4403 times)
Offline justin71105
« on: November 27, 2016, 02:51:59 pm »
I have the shackle on and it hits the bed mount, I searched and read that I can notch tbe bed mount and get it to work right.  Right now as it sits it raised the truck 2" instead of dropping it.
I also have the hangers to change out, I only have a passenger side tank.  Is their a way to get the rivets out without moving the tank out of the way.  I have a grinder but it will not reach all the rivets.
Sent from my SAMSUNG-SM-G850A using Tapatalk
1964 C10
Offline justin71105
Re: 2" shackle and 2" hanger
« Reply #1 on: November 27, 2016, 02:52:21 pm »
1964 C10
« Reply #2 on: November 28, 2016, 11:27:20 am »
you have to notch the bed with a shackle kit for that to clear.  Don't drive it like that.
are you removing the front shackle?  I can't remember as it has been a while but is there not enough space for a air chisel?
I generally just run flip kits or drop springs.
Offline justin71105
« Reply #3 on: November 29, 2016, 04:54:19 pm »
I did the notch already, not pretty but will work until I can get the bed off and drop the tank to get the hanger rivets out.
Unfortunately I do not have an air compressor to use an air chisel, been using an eletric grinder.  I may see if I can use a friends to get the rivet heads off, after their out it seems pretty simple to swap out hangers.
« Last Edit: November 29, 2016, 09:12:36 pm by justin71105 »
1964 C10
