Author Topic: would a 305 fit in my truck and trans?  (Read 5409 times)
Offline Macaroni_Sackaroni
« on: December 03, 2016, 09:16:22 pm »
would a 305 from a 72 c10 fit in my 75 c10 with a TH700R? are they both 2 bolt
Offline hatzie
Re: would a 305 fit in my truck and trans?
« Reply #1 on: December 04, 2016, 07:38:01 am »
Are you sure it's a 305?
The stock "near 300cid" displacement V8 for a 72 CK series would be the 307 Chevy.  GM stopped using the 307 Chevy in 73, and the 305 arrived in 76.
All of the 307 blocks were 2 bolt mains.
A 307 with 305 heads will pull away from a 305 pretty quick with exactly the same heads and cam.  You can use the 059 casting L30 Vortec 305 heads on the 307 but you'll need a Vortec intake manifold.
The 305 is a small bore 350.  The 3.736" 305 bore is smaller than the 307 3.875" bore so the 307 will breathe better.
The 307 is a stroked 283 using a 327 crank.
« Last Edit: December 04, 2016, 07:57:14 am by hatzie »
« Reply #2 on: December 04, 2016, 10:58:24 am »
the guy selling it says its a 305
heres the number GM355909
i looked into it and didnt find any 305 motor with that casting. but thats what the guy said so i made this post.
cl ad
http://sfbay.craigslist.org/eby/pts/5902772724.html
« Last Edit: December 04, 2016, 11:00:56 am by Macaroni_Sackaroni »
Offline hatzie
« Reply #3 on: December 04, 2016, 06:15:59 pm »
Two smallblock engines used that casting.  Without a picture of the stamped engine code number you can't be sure.
355909 1975 262 V8 2 bolt main
355909 1976-1979 305 V8 2 bolt main
"block has to be rebuilt had a blown head gasket"  The seller knows there's more wrong with it than a blown headgasket.
$400 is way too much for an unknown condition 305 core even with a functional TH350.
« Last Edit: December 04, 2016, 06:19:00 pm by hatzie »
« Reply #4 on: December 05, 2016, 10:36:04 pm »
Ditto on the price analysis..  I wouldn't give $100 for the motor.
« Reply #5 on: December 10, 2016, 11:23:21 pm »
thanks yeah i thinkk your right.
