Author Topic: 1984 GMC K10 Build  (Read 79286 times)
Offline GMCMedic
Re: 1984 GMC K10 Build
« Reply #75 on: March 29, 2017, 01:33:19 pm »
All the return lines on my truck were 5/16", the vent lines were 1/4".
At least you can stretch 1/4" over 5/16", but it is much harder to properly clamp 5/16" to 1/4".
I guess that would make sense different years may use different size lines. Im eliminating the charcoal cannister (it wasnt hooked up anyway and the 5/16 line was gone). It made for a really interesting night trying to figure out what was what. It wasnt terribly hard till we starting thinking too much about the size of the return line vs the selector valve.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Offline GMCMedic
« Reply #76 on: March 29, 2017, 02:24:27 pm »
Those wheels came out great.
here is a before picture of the last rim. Its actually not bad compared to the other 3.
Offline GMCMedic
« Reply #77 on: March 30, 2017, 07:03:51 pm »
Finished the shocks today. Installed the front speakers in the dash, undercoated and moved the bed. Yada yada
Offline philo_beddoe
  • 77 C-10
« Reply #78 on: March 30, 2017, 10:12:13 pm »
I'm one up on ya, i can start my truck and drive it, bedless though. Next step is spray in bed liner, then pretty much done.
Are you sure you want to cover up those beautiful bed rails with the diamond plate?
Offline GMCMedic
« Reply #79 on: March 30, 2017, 10:27:52 pm »
This truck will be used as a truck, the bed rails wouldnt be pretty for long. I plan on driving it till the cab corners and rockers rust out again.
Motor goes in Tuesday and then its pretty much at a standstill till Classic Industries ships me the bolt kit thats been out of stock forever (I should get it next week). Also waiting for square hole washers from Fastenal so I can manage to take the bed off again later.
  • 77 C-10
1984 GMC K10 Build
« Reply #80 on: March 31, 2017, 10:07:26 am »
Ok, gotcha. In that case your doing the right thing.
My truck will be used also......TO HAUL COTTON BALLS. Lol
However, i am looking for a work truck.
« Last Edit: March 31, 2017, 10:09:18 am by philo_beddoe »
Offline GMCMedic
« Reply #81 on: April 02, 2017, 08:14:36 pm »
I came across this while looking for  new air cleaners.
Too bad theyre steel valve covers. Would have looked good with my paint
« Last Edit: April 02, 2017, 08:41:09 pm by GMCMedic »
Offline GMCMedic
« Reply #82 on: April 03, 2017, 10:27:58 pm »
I have a motor
Offline GMCMedic
« Reply #83 on: April 04, 2017, 11:02:43 am »
Now half of the tires are on. Getting close
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #84 on: April 04, 2017, 02:46:48 pm »
Are the tube steps made for the truck or did you custom make brackets?
 1986 Chevy K30(under repair)
Offline GMCMedic
« Reply #85 on: April 04, 2017, 03:13:41 pm »
They appear to have been made for it but I cant say for sure. They were on the truck when i bought it.
Offline LTZ C20
« Reply #86 on: April 04, 2017, 05:59:54 pm »
A handful of companies still make tube steps for these trucks with the brackets needed. Some are cab length and some are cab and front half of bed. By looking at his picture, the step pads indicate those are SmittyBilt brand steps. I think SmittyBilt, Westin, Summit Racing, Nerf and a few others are the ones that make sets for squares.
Sent from my SAMSUNG-SM-G890A using Tapatalk
LTZ Cheyenne C20
« Reply #87 on: April 04, 2017, 07:27:39 pm »
Guess I need to search harder, although I haven't decided if I do want steps, do like them on the 2009 Chevy work truck though.
Offline GMCMedic
« Reply #88 on: April 06, 2017, 06:34:17 pm »
Installed audio and did some other misc stuff today.
Waiting on a large parts order to reassemble the interior and front end.
I also finally talked my buddy into trading me his holley 570 for my 850 double pumper. Itll go much better with his step side show truck than it will with my daily driver.
« Last Edit: April 06, 2017, 06:35:54 pm by GMCMedic »
Offline GMCMedic
« Reply #89 on: April 10, 2017, 08:31:11 pm »
Looks like $1200 in parts will be delivered tomorrow. Ill still be waiting on my grill but this should be about the last of it.
