Author Topic: 87 Chevy crew cab build Ls swap with lots of pics  (Read 240638 times)
Offline hwh
Re: 87 Chevy crew cab build Ls swap with lots of pics
« Reply #225 on: August 14, 2017, 11:21:07 am »
The guy that did liner uses rhino lining. I've had a truck with line x. And trucks with rhino lining. And the line x is thin and smooth and peeled off after using bed. The rhino lining never did its thicker and rougher. Very happy with way it turned out. If your wanting to do it yourself. You can buy it from them direct. Rhino linings.com.
« Last Edit: August 14, 2017, 11:28:12 am by hwh »
Offline hwh
« Reply #226 on: August 20, 2017, 02:04:22 am »
Testing out a 35" and 37" tire.
Offline hwh
« Reply #227 on: August 20, 2017, 02:08:10 am »
The 37" tire clears fine and doesn't hit anything with wheel turned all the way both ways. I'm still undecided like to use 35" tires since going to be daily driven.
Offline hwh
« Reply #228 on: August 20, 2017, 02:10:54 am »
Sunday I'll finish up all the cleaning and stuff from paint and body aftermath. Then I'll start putting outside stuff on be able to see it coming together. And decide on what size tire so can order them.
Offline hwh
« Reply #229 on: August 20, 2017, 04:27:56 pm »
Got door handles and key locks on front doors. Door handles were a pain getting rod in hole on door latch. Still have rear door handles to do I'll do those another day when I'm fresh lol.
« Last Edit: August 20, 2017, 10:42:15 pm by hwh »
Offline hwh
« Reply #230 on: August 20, 2017, 04:29:01 pm »
Front and rear bumpers on. And front grille is on grille was painted gray color of truck every place there was chrome. And the insert was painted black. And part around headlight bezels. Didn't like how they painted insert a gloss black. So already bought new grille and dropped it off different place to get repainted. Just put that one one to see front together. Want it semi gloss, like on newer trucks grille.
« Last Edit: August 20, 2017, 04:42:23 pm by hwh »
Offline hwh
« Reply #231 on: August 20, 2017, 04:35:28 pm »
The 35" tire is on front. 37" tire on rear. So decided on going with 37" tires. 35" looks to small for my taste. Had 37" on front and turned tire back and forth good clearance all way around. So I'll order tires Monday.
Offline hwh
« Reply #232 on: August 20, 2017, 04:58:08 pm »
Pics
Offline hwh
« Reply #233 on: August 20, 2017, 10:40:44 pm »
Mirrors are on those are painted same color as truck. The place that's going to tint my windows does that clear wrap stuff there putting on new vehicles like on hood, side body parts. Going to get them to put clear stuff on backside of mirrors where its painted. So help prevent rock chips.
« Last Edit: August 21, 2017, 05:51:09 pm by hwh »
Offline hwh
« Reply #234 on: August 23, 2017, 05:49:43 am »
Tires are ordered I'll have them on truck this weekend. Get rest of outside of truck done.
Offline hwh
« Reply #235 on: August 25, 2017, 04:10:31 am »
New tires are on
Offline hwh
« Reply #236 on: August 25, 2017, 04:12:15 am »
Cowl back together and swing case toolbox.
Offline hwh
« Reply #237 on: August 25, 2017, 04:14:08 am »
Hood insulation kit to finish off engine bay.
Offline hwh
« Reply #238 on: August 27, 2017, 04:32:15 pm »
Got headliner back from getting recovered.
Offline hwh
« Reply #239 on: August 29, 2017, 06:53:28 pm »
Headliner is done. I ended up asking place recovered headliner. If they could send one of there guys to my house to install it and they did. More I thought about decided not to do it myself since never had headliner before no holes for trim where there. It took the guy 8 1/2 hours to do it with me helping. So I'm glad I went that route.
« Last Edit: August 29, 2017, 06:55:47 pm by hwh »
