Author Topic: Replacing Transmission/Torque Converter  (Read 19224 times)
Offline Jon87V20
« on: February 01, 2017, 02:06:53 pm »
So I finally pulled my transmission over the weekend. To my surprise the bell-housing had a giant crack going through it (see attached photo), and my torque converter seemed to be broken as well (tons of play in it). I was able to find another Turbo 400 and I bought a new torque converter as well. When I was removing the transfer case, I found that the large stabilizer bar that runs from the transfer case to the bell-housing, was only connected on the transfer case side. Someone had removed and/or lost the bolts on the engine side. Could this have been a contributing factor in the transmission case cracking?
Does anyone have any tips for re-installing these, or things to watch out for? It took me months to save up to start putting the truck back together and I want to take all the precautions not to mess anything up as I can't afford to replace these again. It's been suggested to me that I should be sure to flush the transmission cooler before re-connecting it. Is there a way to do this at home in the garage on the cheap? I'm going to replace the engine's rear main seal while I'm in there as it appears to be the cause of a messy leak down there.
Is there any special procedure to installing the torque converter? Do I need to fill it first? How much? Does it need to be seated a certain way to prevent damaging it? Just really nervous about doing something wrong. Also, to make matters worse, I had to cut the exhaust out to get the tranny out, as it was a solid chunk of rust so it's going to be extremely loud when I test it. I won't be able to hear any noises. I'll probably have to wait to fire it up until I have the new exhaust in place I suppose.
When I pulled the rear slip-yoke out of the transfer case, I noticed a bit of fluid on the shaft. Is this normal, or does this indicate that I may need to replace a seal there?
A bombardment of questions here, but I thank you in advance for any advice!
'87 Chevy Suburban V20 350ci TH400 NP208
-Jonathan
« Last Edit: February 01, 2017, 02:38:42 pm by Jon79K15 »
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: Replacing Transmission/Torque Converter
« Reply #1 on: February 01, 2017, 02:22:20 pm »
Are you talking about installing the braces?  If so the go on last.
On the converter I put a couple quarts (enough that it can tilt and not bathe me)  slide it in and with slight pressure turn it until it seats.
squarebody.biz
Offline Jon87V20
« Reply #2 on: February 01, 2017, 02:49:40 pm »
Captain, I was talking about this stabilizer/brace that goes on the side of the t-case (see attached photo). Could not having this attached on both sides cause some kind of stress that could contribute to the transmission case cracking like that?
« Reply #3 on: February 01, 2017, 03:20:32 pm »
Loose bellhousing bolts, bad mounts, excessive stress and the like can cause it. The support hooked up will certainly help prevent it from reoccurring but check  your mounts too. You should have 3 engagements of the torque converter, the pump gear, the stator and the turbine. Install it when you are ready to install the transmission as so that it is not hanging on the seal. Lube it with ATF and fill it as Captkaos suggested. When installed you should be able to easily rotate the TC before fastening it to the flexplate. Do no fully tighten all of the bolts until all 3 are in. Use a little thread locker and tighten them fully only after you've tightened all bellhousing bolts. As far as your exhaust goes, just slip on a connector and some exhaust clamps to get you up and running.
Offline Jon87V20
« Reply #4 on: February 03, 2017, 03:31:08 pm »
Ok thanks. Also, what do you call the gasket between the transmission and t-case where they bolt together?
Offline hatzie
« Reply #5 on: February 05, 2017, 09:17:31 am »
The transfer case to bellhousing brace is a good preventative measure.  The intended function of that brace was to keep the bell from cracking.  I wouldn't run her for long without one.
The brace bolt-up is shown in the below illustration as well as the gaskets.  You can also see where they ran the transfer case vent to the rear of the engine...  I ran all my axle, trans, and xfer-case vents up there.
All you need is a longer bellhousing bolt or stud for the bar.  www.gmpartswiki.com/getpage?pageid=56919
The TH400 is RPO M40.
« Last Edit: February 05, 2017, 09:34:21 am by hatzie »
« Reply #6 on: February 05, 2017, 09:24:08 am »
It's just called a gasket, no special name for it.
Offline fitz
« Reply #7 on: February 05, 2017, 05:23:36 pm »
You can use this to clean the cooler & lines.
Offline Jon87V20
« Reply #8 on: February 06, 2017, 09:28:04 pm »
Oh nice! I've never seen that before. That definitely makes things easier.
Offline Jon87V20
« Reply #9 on: February 06, 2017, 09:56:39 pm »
If I have trouble tracking the gasket down at the store, is this something that I can RTV, or is that a bad idea?
« Reply #11 on: February 07, 2017, 03:10:15 pm »
Anaerobic Sealer
Offline 82silverado
« Reply #12 on: February 07, 2017, 06:08:08 pm »
Anaerobic Sealer
Yup. I tell them that at work all the time. Nobody listens though.
82 Silverado 454/700R4
86 Buick GN
02 WS6
« Reply #13 on: February 07, 2017, 07:20:22 pm »
Offline Jon87V20
« Last Edit: February 08, 2017, 01:15:18 pm by Jon87V20 »
