Author Topic: wire identification  (Read 17163 times)
Online bd
Re: wire identification
« Reply #15 on: March 06, 2017, 09:28:26 am »
Welcome to the site!
Left and right are always from the driver's perspective - left is driver side, right is passenger side.  Does the HVAC blower work on high?  What are the wire colors in the two plugs (some of the wires are obstructed in the posted image)?
Offline Matt_lngoerp
« Reply #16 on: March 06, 2017, 12:09:27 pm »
No the blower does not work on high it does however work on the first three and the exit just to the driver side of the HVAC box
Online bd
« Reply #17 on: March 06, 2017, 02:21:56 pm »
With that in mind, the 10-gauge red wire with the ring terminal end is probably the B+ feed to the high blower relay.  If you have a DVOM check for B+ on the red wire at the blower relay.  If it's dead, jumper the ring terminal to the firewall junction block and recheck for voltage on the red wire in the blower relay connector.  If the red wire proves to be the relay feed, then the green wires feed the A/C low pressure cycling switch and idle solenoid.
« Reply #18 on: March 06, 2017, 05:33:47 pm »
Sweet I will check when I get home OK so now I have a few more electrical problems 1 on the wire harness what color wires feed what gauge ......None of my gauges work and would like to keep all factory gauges 2 my fuel gauge didn't work when I got the truck fuel gauge didn't work I pulled bed off well the pink wire on sender was unplugged I plugged it in and fuel gauge worked perfect well I went to put gas in it after that tank was empty and when I got back in gauge was on empty I tried a different gauge and same prob idk what is going on with it
Online bd
« Reply #19 on: March 06, 2017, 06:00:40 pm »
For details on wiring colors and connections, download the 1986 Wiring Manual to your PC.
If none of the gauges work, begin by checking the fuses.  If the fuse is good, unplug the tank sending unit.  Does the gauge swing past Full to ~3:00 o'clock?
« Reply #20 on: March 07, 2017, 04:35:26 am »
Someone cut the wires outta the truvk so I have about 6 inches of wire by the firewall
« Reply #21 on: March 08, 2017, 07:31:22 am »
the pink wire is cut?
« Reply #22 on: March 09, 2017, 05:42:17 pm »
No the pink wire is there but all the others for the gauges are temp oil press and im guessing the volt gauge are all cuti have no gauges
Online bd
« Reply #23 on: March 09, 2017, 05:58:48 pm »
Voltmeter connections are all internal to the cab, behind the instrument cluster.  Engine coolant temp wiring is dark green, engine oil pressure is brown.  Have you looked at the factory wiring manual I linked or had a chance to try any of the suggestions for the fuel gauge?
