Author Topic: TH-350 Tailstock swap!!!!  (Read 3163 times)
Offline kperk
« on: March 20, 2017, 04:27:30 pm »
Hello!!
I have an 84 C1500 with a 355 and a TH-350 with a 9" tailstock and a stock converter.  I am making this truck into a little street/strip project, and a buddy of mine has a freshly rebuilt TH-350 with a shift kit and stall converter in it for DIRT cheap! BUT it has a shorter tailstock!! Am I pooched OR can I just simply swap the tailstocks or am I basically have to completely rebuild the tranny?
Any info or insight would be GREATLY APPRECIATED!!!
Thank you!
Re: TH-350 Tailstock swap!!!!
« Reply #1 on: March 20, 2017, 04:59:35 pm »
The tailshaft housing correlates to the output shaft length. It would be cheaper to have your driveshaft resized.
« Reply #2 on: March 23, 2017, 09:43:40 am »
i ran into the same issue in my 86. the th350 in it was burnt up it had the 9". my buddy had a 6" so i had to find a new/used driveshaft. ended up finding a 2 piece in a bone yard and use that one
Offline hatzie
« Reply #3 on: March 23, 2017, 11:11:55 am »
Just change the driveshaft and move the transmission crossmember.
Pretty easy to do.
