Author Topic: Gen V 454 into 88 V20 burb  (Read 20198 times)
Offline MuddiGGEr25
  • Wrencher
Re: Gen V 454 into 88 V20 burb
« Reply #30 on: May 28, 2017, 07:25:51 am »
So, ive got everything done except the temp guage, OP gauge, tach, and Vac gauge ( the last 2 are brand new) It did start yesterday (see youtube link below). After that just to connect the exhaust and T the heater core into the cooling loop
PS, i did finally find the old port in the block, passenger side about 2" from the dizzy, and someone had siliconed a bolt into it, well i gave it a good twist and it popped right out, and i could not for the life of me get the aluminum threads/adapter out of there, so i used JB weld Steel stick putty (good for 300F, and 900 PSI IIRC) and made my own plug and im going to use the bypass hose to get me the heater core source, there was a 1/2" NPT plug right next to the screwed up port but even with a 40" bar on my 3/8" rachet, i could not break it loose so i said screw it.
Today after work (4pm) im gonna fill all the fluids, and let it idle until it reaches operating temp and see if anything blows off or any clamps need tightening
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Offline MuddiGGEr25
  • Wrencher
« Reply #31 on: May 28, 2017, 07:26:44 am »
