Author Topic: CUCV Grille  (Read 7618 times)
Offline Darth Goofius
CUCV Grille
« on: March 16, 2007, 10:32:00 pm »
I was hoping that someone could confirm an observation I made.  I am in waiting to take delivery of an '86 M1009 (CUCV Blazer).  I noticed that all of the CUCVs, no matter the year, seem to have the '83-'84 style grille.  Is this correct?  Even though mine is an '86 I want to be sure that for the CUCV it should have the earlier style grille.  Thanks for confirming or refuting my observation.
1986 M1009
Offline Tire Burner
Re: CUCV Grille
« Reply #1 on: March 19, 2007, 03:25:00 am »
Well, something that you MIGHT want to remember. All of the Military Vehicle Chevy trucks have a Square hole cut in the upper right side of the Grille for the Blackout Drive Light. If you're looking for a good replacement Grille, Military Vehicles are a poor Choice.
Re: CUCV Grille
« Reply #2 on: March 19, 2007, 05:54:00 am »
Perhaps you misunderstand.  The vehicle I have is a M1009.  So, I will be needing those holes.  I am just wanting to be sure in the event I can not find a military grille to begin with.
1986 M1009
Re: CUCV Grille
« Reply #3 on: March 19, 2007, 07:31:00 am »
Not quite sure, but if you are asking if an 83-84 grill will fit in an 86 it will. 81-87 are all the same dimension. The 4 headlight set up placed the directional / park light behind the grill in the bottom corners, but they will still fit. The 83-84 style only differs as it has more horizontal bars, their leading edge is beveled back on the top, and the vertical bars are les pronounced and set in a bit. My personal opinion they are the best looking of all the grills from the 81-87 models. Hope this helps if not please give some more detail.
P.S. Welcome from N.H.
Edited by: Blazin at: 3/23/07 8:07 pm
Re: CUCV Grille
« Reply #4 on: March 23, 2007, 08:39:00 pm »
Ok, that is then as I thought.  The CUCV grille has the larger number of slats just like the '83-'84 grille.  Thanks.
1986 M1009
