Rear Drivelines, Drive Axles and Gearing
What is this and its function?
Topic: What is this and its function? (Read 8555 times)
philo_beddoe
77 C-10
April 13, 2017, 09:53:51 am »
I dont have a pic yet, but its a black hose coming from top of rear diff and attached to bottom of bed. It has a plastic button type thing that pushes in and out.
csdineley
Re: What is this and its function?
April 13, 2017, 09:55:39 am »
Vent tube.
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
April 13, 2017, 12:48:34 pm »
It's a breather connected to the vent hose.
⌠ŻŻŻŻŻ' [☼===☼]
philo_beddoe
77 C-10
April 13, 2017, 02:09:58 pm »
Does air go both ways or just vent out?
GMCMedic
April 13, 2017, 06:43:46 pm »
What they said
Sent from my SAMSUNG-SM-G920A using Tapatalk
philo_beddoe
77 C-10
April 13, 2017, 10:25:02 pm »
Got it...."vent"
April 14, 2017, 07:29:56 am »
It's designed to allow venting as the axle and lube heats up. As it cools, a negative pressure closes the valve. For normal use they are fine but can fail which typically leads to failed axle seals, pinion seals, water intrusion etc. Some people prefer to run a small filter vent with no valve and a relocated hose if they do off-roading or mud bogs. Unless you are seeing leaks and water intrusion, just leave it be.
⌠ŻŻŻŻŻ' [☼===☼]
philo_beddoe
77 C-10
April 14, 2017, 10:32:01 pm »
No leaks or water, it was grimy, so i just cleaned it up.
