Author Topic: Minimal wires required to operate 1987 TBI  (Read 3619 times)
Offline MuddiGGEr25
  • Wrencher
« on: April 18, 2017, 08:25:32 pm »
Ok ive got the 1987 350 mounted into the 1986 K5, ive found a pink/black stripe wire im using for HOT in RUN or START, i have run a 30A waterproof inline fuse from the BAT + and am running a relay for the ECM 1 and ECM B circuits. I also made sure to connect the orange lead to the PCM directly after the fuse so that it has constant 12V+.  I am getting the signal for the fuel pump, and its turning on like normal (i need to prime it, but for my tests i used starting fluid right down into the bores of the TBI)
I am not however getting spark signal yet, and i havent tested to see if im getting injector pulses, but i do know they are both geting power. i tossed my back out at work today, and its dropping fast outside (like only 45F right now and dropping to 33F) so i called it quits for tonight.
Im not totally concerned with getting the dash working as this will only be a daily driver for long enough to get the suburban back together, and will be getting a set of mechanical gauges anyway so im not really worried about getting those hooked up except maybe the temp.
I still have like 4 wires that went into the fusebox area on the old firewall that are not connected to anything, and i have 2 plugs that dont have anything connected to them, possibly a 3rd, ill have to crawl under and take a better look.
I just want to know what is the bare minimum connections for the TBI to start pulsing the injectors and the coil? EGR and O2 are irrelevant right now, just want to it to fire over, then i can start ironing out the kinks
I went to the thread at http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.0
but that hasnt really been very helpful other than the basic power and ignition wires, my colors dont match up and it keeps mentioning : carb control this, carb control that" and i dont have a carb... soo
any good resources for the "first gen" TBI?
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Offline MuddiGGEr25
  • Wrencher
Re: Minimal wires required to operate 1987 TBI
« Reply #1 on: April 19, 2017, 04:33:06 pm »
Im so done with my life, so i tested all the wires coming in and out of the PCM, and pretty much got perfect results, and i couldnt figure it out for the life of me, then i rememebered that i sometimes had problems with the red wire on the connector that runs from the igntion coil down to the ICM in the dizzy, and i pulled the tape off and lo n behold, it was snapped off, so i robbed the TBI 454 connector and put it on, and drizzled a little fuel into the TBI, and it fired up instantly and even idled perfect for about 5-10 seconds until the fuel ran out. now attaching the exhaust and gonna get some gas after my Brother in law gets off work tonight (im not walking nearly a mile with my knees)
tomorrow should just be priming the fuel lines, then start it, and fill fluids, then test drive
PS I wouldnt mind if I could still get some of the first gen TBI info if anyone comes across some
