Author Topic: Dallas TX Area LS Swap  (Read 11692 times)
Offline Chevy Boi
« on: April 19, 2017, 09:40:00 pm »
Looking for a reasonable shop in the area to complete an LS swap on my 81 c10. Im mechanically incline but dont have the space to complete the job. ALL suggestions welcome!
Thanks in advance!
« Last Edit: April 20, 2017, 02:23:47 pm by Chevy Boi »
Online Rapid Roy
  • Euless, Texas
Re: Dallas TX Area LS Swap
« Reply #1 on: April 20, 2017, 06:20:42 am »
I started using a small shop in Euless. They have done front end work for me last fall. So far they are a good repair shop. They have my 74 C10 right now repairing fluid leaks and AC. If you are interested, I can give you name and address. Not sure if you are interested going to Euless.
Mopar by Birth
Chevy by Choice
Offline roundhouse
« Reply #2 on: April 20, 2017, 10:06:23 am »
We did ours in the driveway
I live in a city but no HOA
I could never live with an HOA
Too many rules and not enough trees
Every place with an HOA always has the houses crammed up too close to each other for me
I only have 1/2 acre but the house is 80 feet from the street
City ordnance says no "inoperable " vehicles
But as long as it has inflated tires and you throw a car cover on it when you're not working on it the city doesn't care , as long as it appears operable
« Last Edit: May 28, 2017, 07:41:36 am by roundhouse »
« Reply #3 on: April 20, 2017, 11:56:10 am »
around here as long as you have tags youre good and even without tags you have something like a limit of 5 or higher, never pressed the issue
Offline hwh
« Reply #4 on: April 20, 2017, 05:15:08 pm »
im using dans customs in granbury. dan 817-504-4457. he is doing my 87 crew cab. you can look at the pics of my truck. my truck is at paint and body shop. once its done its going back to him to finish everything. you can tell him heath sent you his way. my build forum is under 87 chevy crew cab ls swap with lots of pics.
Offline hwh
« Reply #5 on: April 20, 2017, 05:17:04 pm »
he is reasonable
