Author Topic: Need stainless fuel lines and steel cooling line - 1987 Chevy Silverado 4x4  (Read 3584 times)
Offline Mike Phillips
Need a sources for the below...
One of the stainless fuel has exposed rubber from where stainless steel has worn away.  Looks to be leaking.
This is a cooling line that comes from the heater core on the firewall to the back of the motor.  It's one piece and the rubber hose portion is worn and the metal tube portion is kinked.
for the fuel line
https://www.napaonline.com/en/p/NDP7002367
this is all im seeing its just a fitting and line to repair you old line.
for the heater hose
#7 with A/C: 15554921
#7 w/o AC: 15554920
http://www.wholesalegmpartsonline.com/products/PIPE-Heater/2746004/15554920.html
But it appears to be discontinued
you might be able to find more stuff
http://www.wholesalegmpartsonline.com/productSearch.aspx?ukey_make=1024&ukey_model=14532&ukey_category=0&modelYear=1987&ukey_driveline=0&ukey_trimlevel=0&ukey_modelRange=0&isOnSale=0&searchTerm=
