Author Topic: hard starts 20+ mins after shutting off hot  (Read 25505 times)
Offline roundhouse
Re: hard starts 20+ mins after shutting off hot
« Reply #30 on: May 29, 2017, 08:11:53 am »
The Holley metal heat shields could also help
You may wind up with an electric fuel
Pump at the tank and a restricted return line
To keep the fuel cool
The ethanol garbage that the fedgov puts in the gasoline is most likely the problem
But it's really hard to find gas without that crap in it
Offline Monkey Uncle
« Reply #31 on: May 29, 2017, 02:59:27 pm »
http://pure-gas.org/
Supposedly there's a station in my town that still sells E0 gas.  I might have to check it out next time I'm running low.
Offline blazer74
« Reply #32 on: May 29, 2017, 03:45:17 pm »
2.77 gal near me last look couple months ago.
Haven't tried it tho.
Edit, might have been 3.77
« Last Edit: May 29, 2017, 03:47:21 pm by blazer74 »
« Reply #33 on: May 30, 2017, 01:02:57 pm »
airports also sell e0
Offline 1979SIERRAGRANDE
« Reply #34 on: June 02, 2017, 05:27:56 pm »
air ports like small private runways?
Offline big_al273
« Reply #35 on: June 02, 2017, 09:01:01 pm »
piston engine planes are still burning old school leaded gasoline
https://en.wikipedia.org/wiki/Avgas
and at least up here in Canada if you want pure gas with no ethanol bs than you have to pony up for premium (91 octane) and it's usually at least $0.50 more per liter than regular (3.8 liters per 1 US gallon) sometimes more
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #36 on: June 02, 2017, 10:12:47 pm »
they cant burn the ethanol and is illegal for them to use it so they have to use the good stuff
Offline big_al273
« Reply #37 on: June 03, 2017, 07:59:20 pm »
never heard of ethanol being illegal in aircraft although i could see it having issues with water content and freeze ups, all i know is that when the governments decided to mandate no more leaded gas they included a permanent exemption for aviation fuel
« Reply #38 on: June 03, 2017, 08:28:59 pm »
maybe im mistaken about it being illegal. thought i read that years ago but maybe it was something else or im combining the lead fuel with issues with ethanol
Offline need4fun2469
« Reply #39 on: June 16, 2017, 03:29:56 pm »
Marina's also sell ethanol free gas.
Sent from my SM-N900P using Tapatalk
« Reply #40 on: October 01, 2017, 09:31:50 am »
I know this thread is old, but since this seems to be a recurring topic, I figured I'd give an update on recent experience.  I put in a tank of ethanol-free gas, and it greatly reduced my hot start issue.  It's not completely cured, but I still had close to 1/4 tank of E10 when I filled up, so hopefully it will continue to improve if I keep using E0.
Offline blazer74
« Reply #41 on: October 02, 2017, 03:00:52 am »
I've had my blazer since 88 and never had problems until 5 or so years ago.
My problem is more like  vapor lock after sitting the same approx 20 minutes.
Starts ok but stumbles shortly after with mild  acceleration and almost always on Heavy and WOT when hot.
Tried non E gas and helped but didn't cure that's it. Seems even the non E gas is still not the same as gas from years ago.
I added a fuel filter with the vapor 3rd port  just before the carb and routed the vapor line back to the tank thru the evap can line eliminating the can for testing.
Also leaving the gas cap loose to prevent pressurizing the tank from the return.
This seems to have cured the problem but too soon to tell.
Going to replace the tank sending unit with one 4 lines so I can use the vapor return and the evap can if I'm satisfied I've cured the problem.
Actually already have the unit to install as well as have already intalled the vapor return Line on the frame rail.
Offline Dr_Snooz
