Author Topic: Can I ask?  (Read 6871 times)
Offline Tazman
Can I ask?
« on: July 17, 2017, 05:37:48 pm »
I am getting used to driving my b92 GMC but it will never replace my 87.It drives nice, sounds great,and the air works super which important this time of year.
Now it has its fuel pump in the tank as the 87 did but I do not hear it start when I turn the key, is that normal? I have also been told that these 305's had an issue with the manifold gaskets failing much earlier than usual, anyone know if this is true?
Thanks,
God BLESS AMERICA
Re: Can I ask?
« Reply #1 on: July 18, 2017, 02:33:24 pm »
its pretty much the same setup. you should hear the pump prime when the key is first turned "on". if not the fuel pump relay could be bad, on a cold startup does it take 5 or so seconds of the engine turning to start?
Offline AZ4X4SQBDY
Re: Can I ask?
« Reply #2 on: July 18, 2017, 06:44:10 pm »
I remember some of the OEM fuel pump assemblies having one of these and the replacements not having it
http://www.rockauto.com/en/moreinfo.php?pk=6436689&cc=1059825&jsn=580
They said it's the same from 87-92. What it does is cuts the noise down from the pump.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Offline Tazman
Re: Can I ask?
« Reply #3 on: July 18, 2017, 08:12:39 pm »
No it starts just fine but it does not like to go 25 mph till its warmed up. It can stumble but never dies.
God BLESS AMERICA
Re: Can I ask?
« Reply #4 on: July 18, 2017, 09:39:00 pm »
seams like you have a few issues
is your check engine light on?
does it come on when you turn the key "on"
how to retrieve OBD codes
how to test TBI sensors
Offline AZ4X4SQBDY
Re: Can I ask?
« Reply #5 on: July 18, 2017, 09:53:44 pm »
Meter the coolant temperature sensor, make sure the ecu is getting the right reading. This may not set a lamp.
Offline Tazman
Re: Can I ask?
« Reply #6 on: July 19, 2017, 07:03:20 pm »
No lights, no codes
God BLESS AMERICA
Re: Can I ask?
« Reply #7 on: July 19, 2017, 07:12:36 pm »
The 87-93 TBI motors were pretty much the same.
